Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By VBRED
Thread: 202 engine
    vk :tunnelram v6 carby
    Nov 2011
    tatura
    Default 202 engine
    what would be a suitable combo for a red 202 burnout car engine in a vk commodore and how would you set it up ill be useing a electrnic fuel pump with my set up any ideas or advice im all ears on advice
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    One of those triple weber style injection maybe the go. It may fit, not sure. Prob need an aggressive cam, "HX" grind or better.
    Nov 2011
    tatura
    wann go 400-500 valve lift i used to have a 500 lift cam in my old 250 xflow but thats long gone ford or holden dont matter to me its the way ya build ya engine to how good it will be im playing with my vk and i have no intentions of selling it ever
    vr v6
    Aug 2009
    If you are just going to small local comps leave the motor stock with a 350 holly and extractors.Just change the diff ratio to about 3.9 and run small tyres on the back.Also make sure the motor is in tune.If you start putting large cams and stuff in ,the costs start to become not worth it.I ran the same setup in one of my toranas , it went all right ,even won some comps.
    VH SS
    May 2009
    Toowoomba, Qld
    might be worth considering roller rockers for sustained high RPM
    you don't need big hp to make lots of tyre smoke, so I agree with the post above in regards to not needing big cam etc
    Make sure the cooling system is up to scratch. Maybe a triple core radiator, good fan
    An engine oil and auto fluid cooler might also be a consideration to keep the oil temps down
    Nov 2011
    tatura
    well i have picked up a vt ecotec v6 engine full car that has been hit so im getting a good v6 with 160,000 ks and superchargeing it my vk is set up for a v6 already i had a vr v6 engine in it with custom manifold and was running a 600 holley but wanted to put a v8 in it i brought a 253 but it was stuffed so im back to a v6 but should go alright my vk has a rebuilt 3:45 and spool so the v6 should go hard as
    Nov 2011
    tatura
    or would twin strombergs work just as good or better the a 350 holley the 202 is out of a hz so ya saying if i paint the engine slap chrome rocker and side covers on twin thermos good trans cooler i have a rebuilt diff with 3:45's and spool with no rear brakes so in reality it should smoke and sound tuff
    Black VK Calais 333 Pack
    Jul 2009
    Melbourne - SE
    Supercharger!
  1. missing engine cover bolts 5 litre engine
    By justice4all3000 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-09-2011, 06:17 PM
  2. vx coughing and spluttering after v6 engine swap with wrong engine
    By bogan_vk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-08-2011, 08:11 PM
  3. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  4. VS Ute Engine just fitted but engine light coming on and not going into overdrive
    By MX_Leigh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-10-2010, 04:53 PM
  5. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
