hi guys just woundering if anyone on here has put a vt ecotec v6 in there vk my vk is set up for a v6 used to have a v6 running a 600 holley it wouldnt tune properly so i sold it now going a vt ecotec engine and superchargeing it any tips or how well do u think it will go
you had a v6 eco with a 600 holley? where did you get the manifold?
nah was a series 1 vn v6 with 600 holley i have pics on one of my posts
ari: link below
my fully worked v6 vk
Too much effort if you ask me.
To answer your question tough. Youll need all the appropriate wiring and ecu seeing as though your now putting in a completely new engine.
Supercharged ecotects are everyhwere on this site. A quick search should yeild some results for you to "drool" over i suppose.
97 WRX AWD
Tein Coilovers + EDFC Dampener Control - Whiteline heavy duty Rear sway bar - Whiteline Droplinks front and rear
Turbosmart dual stage boost controller
IHI VF34 Turbo - XForce 3inch TBE - Oversized TMIC - Unichip PiggyBack ECU
PPG Straight cut 1st & 2nd, Slight helical 3rd & 4th and standard fifth - HD Clutch - custom braided clutch line
02 wrx 4pot front calipers - DBA500 two peice slotted rotors - Steel braided Lines
BP98 safe tune @ 171.8awkw
lol. so
step 1. cut off top of manifold
step 2. weld on square bore base plate
step 3. pray it works
step 4. go get a new manifold.
sound about right?
yeah and ya gotta weld up the injector plug holes and put a plate on the throttle body back off manifold
my vn v6 worked but i just couldnt tune the carby properly
Don't bother supercharging an ecotec. Just buy a L67 supercharged V6. Far easier and a much better engine built for boost. The only common part of an ecotec and a L67 is the block.
no i brought a low km series 1 vn engine has cam and worked t700 auto now im thinking of custom making twin throttles on top of manifold with 2 pod filters sticking out the bonnet and keeping a dummy throttle body with no butterfly and plumming up my sc14 supercharger how well do u think this will work or will i have problems with too much air whats ya oppinions
wtf? I want what your smoking or are you just that dumb
Current project VH SL SEDAN 202
http://forums.justcommodores.com.au/...-83-vh-sl.html
Last project VH SL WAGON L67
http://forums.justcommodores.com.au/...h-wagooon.html
