Results 1 to 18 of 18
Like Tree3Likes
  • 2 Post By VK SL 3800
  • 1 Post By the_boozer
Thread: Burnt out valve
    Vs statesman 5ltr
    Mar 2011
    Mt druitt
    Default Burnt out valve
    Does any1 know anything bout valves on a vc
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    They are round on the end, and most commonly found in the cylinder head. whats more to know.
    Vs statesman 5ltr
    Mar 2011
    Mt druitt
    Ok cool are they easy to fix what am I looking at for price and will I need new gaskets??
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    You will need a VRS kit + vales, seats is worn, maybe springs, collets, retainers & shims
    whats the problem?
    Scott
    Wanted 85 VK manual boxey type manual side mirrors not the VL looking ones
    commodore vk auto 3.3
    Oct 2009
    South Coast Region
    A easy way to solve your problem is to get an exchange reco head and all you'll need is a head gasket.Have U done a comp test yet?
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Quote Originally Posted by commy vk View Post
    So what do you do for the thermostat, exhast manifold gaskets?
    Better off buying a VRS kit and chucking the stemseals?
    I do agree esp for the inexperienced an exchange head is the way to go, dont forget to use the holden threat sealant on the bolts so they dont rust in
    Scott
    Oct 2009
    South Coast Region
    Quote Originally Posted by vkberlina View Post
    Scott
    I wish mine was as simple as just a vrs kit but after I got my stem seals changed the smoke became worse than ever,so that's what I did and the problem is fixed.I suppose it all depends on the amount of time someone has to dismantle a head clean it up have it tested and machined.Not only that but how many ppl have got their worshop set up for such an operation?So yeah I'll take the easy way out (changeover) thanks very much.
    ari666's Avatar
    ari666 is offline Jose Arimeintes
    1966 impala, 2011 chevy camaro, 2007 silverado
    Mar 2009
    vk
    Nov 2009
    noble park
    I thought home headjobs with lapping paste went out when unleaded fuel appeared.
    What was the purpose of the lead in super? If you want it to work and dont want to buggerise around for days get a reco head
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Fit new valves and seats to a head without lapping them in and perform a leakdown test, it will dribble like an incontinant 90yearold woman.
    pretty much all valves should be lapped in,, the last head i did I got lazyand put an old cotton buff ball into my cordless drill and on a low speed when nuts, you have to keep stopping and check for correct lapping but its pretty quick and easy
    Scott
    ari666's Avatar
    Mar 2009
    VH SS
    May 2009
    Toowoomba, Qld
    Quote Originally Posted by ari666 View Post
    mate. lapping paste was useless even when there WAS lead in fuel.
    you ever done it???? tallllk about a waste of your life. my god.
    it worked on my old 202
    Had a couple of leaking/burnout valves. I stuck the valve in the end of a reversable drill, some valve grinding paste on the seat and off I went.
    tipped fuel down the inlet to check for leaks and it was sorted. Engine ran puurfect. I know it's a rough as guts method, and I don't necessarily recommend it but I had no plans of hanging onto the engine for a long time, so thought I'd have nothing to lose.
    but the OP seems to have deeper problems. If it's blowing smoke after fitting valve stem seals, then sound like he's got valve guide problems
    Oct 2009
    South Coast Region
    Quote Originally Posted by the_boozer View Post
    I think the purpose of having the lead in the old super grade petrol was to cushion the valve and seat so they don't melt.I could be wrong and someone might correct me on this,maybe someone who works on them for a living.Cheers....Merry X mas.
    vk
    Nov 2009
    noble park
    My oldman don't like spending money yes I've also wasted days of my life doing it, I don't even think a car yard would bother doing it.
    In my case the guides weren't too bad but the head didn't last a year . Maybe when old blokes rebuilt grey motors every 4 months it was the done thing.
  15. #15
    ari666's Avatar
    Mar 2009
    Quote Originally Posted by Darren_L View Post
    CHEATER!!!! lol,
    anyway back on topic, pretty much any time i touch an unknown head i send it to get the valves ground and seats re-cut. its not that $$ think 400 bucks for a pair of V8's inc decking and hot tanking. you may have to shim up the springs after, depending on how screwed the seats are.
  16. #16
    Oct 2009
    South Coast Region
    LOL yep in the good old days we could just get away with a new set of stem seals.
    Oh I can just smell the old Super grade petrol...AHHH
    Can anybody else remember it??
  17. #17
    VH SL/E 5.0
    Nov 2009
    Sadly yes - used to fill my first VH (253!!!) with it......
  18. #18
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Mmmm yes the grey tailpipes
    Scott
  1. Buick valve springs, valve train. need advice
    By GTP 85 in forum V6 Development And Modification
    Last Post: 25-08-2009, 09:22 PM
  2. Valve guides or valve stem rubbers?
    By Drewie in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-05-2008, 02:57 PM
  3. burnt valve
    By VNexecutive in forum General
    Last Post: 29-09-2007, 05:44 PM
  4. Valve guides or valve stem rubbers?
    Last Post: 13-09-2007, 11:05 AM
  5. one piston not firing, not the injector, possibly burnt valve or head gasket?
    By Famine in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2006, 08:59 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
