Results 1 to 8 of 8
Thread: 186 on blue 202 block
    vh slx
    Jan 2012
    Default 186 on blue 202 block
    i have recently put a high comp 186 head on my blue 202 block,
    i now have a boiling problem im pretty sure. i drove the car for almost 100 metres yesterday and the temp gauge went rose to half way so i took it back home and let it cool down i have no idea why?
    since the conversion my battery light is staying on and most of the dash is not working when i first drove it after putting the head on i heard a click behind the dash and the light came on? i have changed the regulator on the altinator but didnt change anything?
    VK SL + LH Torana + VZ Crewman
    Sep 2010
    vh slx
    Jan 2012
    thanks for that, when i put the head on on drilled the holes in the head so they match up, but there isent a hole at the end of the block so i didnt drill one there but im thinking it might be boiling there
    vn
    Nov 2009
    noble park
    you got rid of a 12 port head and put 9 port head on with smaller valves?
    what carby you using? mabe a blown fuse from a wire not used earthing out somewhere.
    Did you have to redrill the block? If the alternator charge light dont work the alternator wont charge
    vh slx
    Jan 2012
    i put a reco 186 head on with bigger valves and port work with a ww stromberg carb,extractors and a cain inlet manifold, yea i thought so to but everything looks alright, but after a few days with a immobilser shouldnt the battery be dead if the altinator is dead?? ive been told it may be a voltage stabiliser behind the dash ?
    i didnt redrill the block at all?
    vh slx
    Jan 2012
    drove it just now still boiling but when i rev the guages that are working are move up with the revs all the fuses are fine and there was a temp sensor wire floating around but thats good now. Still have no idea why thats all shitting its self
    Vc Wagon & Vl Wagon
    Oct 2011
    New Zealand
    I cant remember but there is a difference with the water jackets between red & blue/black, one will be blocked and causing it. I'd say you'll have to take the head of to compare what the difference is, even the head gaskets will be different to......
    vh slx
    Jan 2012
    cheers, im pretty sure when we did it theres a whole in the head and where it should be on the block there isent one at all so yea mayb thats its ill rib it off and have a look, we put wholes in the gasket to suit we used a red motor gasket
  1. Short block ...... Big block?
    By vtv6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-05-2011, 07:23 PM
  2. which V8 block to use red, blue, black motor
    By dave977 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-02-2009, 08:04 PM
  3. blue head on black block 6 cyl
    By CaptainKen in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 17-10-2007, 11:00 PM
  4. blue 202 head on red block?
    By potshots007 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-05-2006, 08:35 PM
  5. blue/black block
    By 9898989 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-02-2006, 08:51 PM
