Results 1 to 10 of 10
Thread: why is my battery light staying on
    vh slx
    Jan 2012
    Default why is my battery light staying on
    my battery light is constantly staying on, half of the functions on my dash arnt working, i get hazards, temp gauge and indicators everything else dosent work, when i was driving it whenever i was reving the oil pressure and volts gauges went up everytime the revs did? i have changed the voltage regulator on the altinator and that did nothing. if anyone could help me figure this out that would be great, cheers
    VY SS
    May 2011
    Auckland
    vh slx
    Jan 2012
    i havent checked those? i have no idea how to check that tho how would? ive been told it may be a voltage stabilser behind the dash
    VH Vacationer 202, VH SL 185 pack 253
    Feb 2010
    Victoria Pt, Queensland Australia
    I once had a gauge that wouldnt work. I changed the dash backing plate and it fixed the problem.
    VY SS
    May 2011
    Auckland
    Is the battery charging? With the car idling measure the voltage across the battery terminals. Should be more than 13v
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    First of all your oil pressure should fluctuate acoring to engine rpm so that sounds normal.
    I would check your earths, engine, dash etc and then see how it goes.
    Scott
    vh slx
    Jan 2012
    i have checked the battery and thr fuses and thr battery terminals everything is fine on that side, i have been told its the regulator behind the dash cause there was a loud click from behind the dash and then all the problems appeared? And i only have a oil pressure switch not sensor im running the gauge because i have a sle dash on it and havent changed the switch to sensor yet so it should go up with rpm if its acting as a idiot light?? I have got the regulator out and it is yellow in some places, looks like its blown but ill take it to work and see?
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    normally when they blow there is a small hole in them, yellowing can be normal 20+ years old heating up and cooling down etc, but probably blown or has a fault I think your on the money
    If your oil pressure guage is instantly flicking scale to scale then it sounds like a power problem but if its moving steadily its normal, if its flicking as your alternator is kicking in your dash voltage reg isnt regulating power properly or you have a bad earth.
    If you get the codes of the reg, im sure Farnell or WES components will have something to replace it with.
    Scott
    green vh 186/202
    Jan 2012
    yeh mate check you ground from your battery to the top of your engine. like clean the shit out of it with sand paper and get it down to clean metal. i had a bitch of a time trying to work out why this was happening to me when i put a 186 head on my 202 block. let us know how u go and if u work out whats wrong.
    vh slx
    Jan 2012
    i cleaned the ground in the engine bay and one under the dash was loose and dirty so cleaned ad tightened it and now everything is workin again, thanks everyone for all you help
  1. air bag light staying on
    By vxdriver11 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-11-2010, 12:38 PM
  2. air bag light staying on
    By vxdriver11 in forum General
    Last Post: 26-11-2010, 07:14 AM
  3. VT - fan staying on after engine off - battery drain
    By Naggets in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-03-2010, 05:31 PM
  4. Air bag light staying on. help?
    By daz08 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-04-2009, 10:31 PM
  5. Oil Light Staying on
    By VNSV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2005, 06:31 PM
