Results 1 to 9 of 9
Thread: same or not?
    Vt Wagon
    Aug 2011
    Default same or not?
    I recently bought a EFI v6 VK sedan as a toy/project. But it needs a new trans. I found one locally cheap from a VL.
    Should be same yes? I know vaguely that the black motor has the crank sensor in the bell housing so you need the late model box... Am I close? Rather not Buy the trans and add it to the pile of car parts in the corner.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Not even on the same planet
    VK had an EFI 6 did someone install a V6?
    VL 6 is also a straight 6 a completely different straight 6
    VK Carb ran a CAS EFI VK didnt
    All VK EFI 202s were Autos is yours still an auto or has someone converted to a manual?
    If its still an auto you need a Trimatic affectionally known as traumatics
    Scott
    Vt Wagon
    Aug 2011
    My apologies. It's a straight 6 EFI
    So I just need your average trimatic?
    Are they same as red motor stuff where the bell housing is separate from the actual trans housing or is that only manual stuff?
    Im usually good at mechanically minded stuff but I haven't dealt with black motors before and tbh I have barely looked at the car.
    The obvious answer seems to be to get my ass out there and pull the box out. See what im actually playing with.
    Black VK Calais 333 Pack
    Jul 2009
    Melbourne - SE
    Mate Do not bother the autos are totally different and will not bolt up. VL = Nisssan VK = Holden
    VB SL/E
    Dec 2008
    I think the EFI 6cyl trimatic was unique as in it was a VK 6cyl casing with V8 internals for example the extra clutch pack.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    They are a moulded unit so the bellhousing is part of the box.
    I remember there was something different about the EFI box I cant remember what it was but a carbie box will bolt up and work. as the black blocks were the same.
    Whats actually wrong with your box?
    Scott
    Vt Wagon
    Aug 2011
    Apparently it doesn't select any gears. I also noticed it's leaking fluid. I winched the car on the trailer and dropped it out the front. It hasn't moved.
    I need to get a battery and see what the box actually does. If it's difficult to get a VK trans, I've got a VK 5litre and a v8 disk brake diff I can always chuck in. Still leaves me with no box though =(
    Vc Wagon & Vl Wagon
    Oct 2011
    New Zealand
    The 6 cylinder efi trans were a 253 trans set up for the 6 as the efi 6's made more power than the 253, i dropped one of the engines in a Vk wagon years ago with a celica 5 speed back to a Vl 3.45 diff. Was awesome with the 5 speed, had no probs leaving two black liquorice strips down the street ;-)
    Vt Wagon
    Aug 2011
    The celica box bolts on? Or I need a conversion?
