Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By vkberlina
Thread: Removing trim
    VK Berlina 5L Project
    Feb 2011
    Ballarat
    Default Removing trim
    Hi guys done a search but couldn't find what I wanted. Just need to know how do I remove this piece of chrome trim. Iv got all the other bits off except this one.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    you need a special tool, your fingers
    just roll it from the window the the rear of the car, then the lower part you undo the screw that is covered by the chrome strip you roll off..
    Scott
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Quote Originally Posted by vkberlina View Post
    Scott
    Im still retarded, can you elaborate further? Do you pull (like trying to roll it off) the back strip towards the front/back door handle?
    I wanted to pull the panel off once while i had it all apart but it felt like id break something so i gave up.
    vn
    Nov 2009
    noble park
    take off the plastic bit around the window will help the 3 screws inside the door opening.
    then the bottom chrome
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Ok
    Order of removal
    1 - the rear sloaping chrome mould
    2 - lower black and chrome mould
    3 - black window surround plastic
    You need to grip the chrome mould by standing towards the rear of the car with 2 hands of finger tips touching the plasic window surround and the pads of your fingers on the edge of the chrome mould and roll it away from the plastic mould towards the rear of the car at the same angle it is fitted.
    Sometimes they can get fairly tight due to dirt and crap getting intot he grooves. it might be worth hoseing behind it a couple of times prior to trying.
    Scott
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Quote Originally Posted by the_boozer View Post
    It wont come off still as there are another group of screws behind the chrome mould
    Scott
    Feb 2011
    Ballarat
    Thanks vk berlina. Got it off first go. Cheers
  1. removing the (floor?) trim...
    By jamex101 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-06-2011, 04:42 PM
  2. Removing Ve door trim
    By IGNITIONSV6 in forum VE Holden Commodore (2006 - ?)
    Last Post: 09-04-2010, 01:38 PM
  3. Removing door trim
    By jb201091 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-04-2010, 05:08 AM
  4. Removing the trim around..
    By danteo55 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-04-2009, 03:58 PM
  5. help removing side trim
    By vrberlina93 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-03-2008, 09:02 AM
