Results 1 to 11 of 11
Like Tree3Likes
  • 1 Post By Darren_L
  • 1 Post By mr j-man
  • 1 Post By VK SL 3800
Thread: Annoying problem
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Default Annoying problem
    Hi all,
    Got a strange one for ya's!
    Every time i turn right the left window sprayer nozzle dribbles water, flicks it onto the windscreen sometimes. No a big deal but its stains the paint from being wet constantly and i keep having to polish it.
    Cant work out why, the other VK wont do it and the pipes seem to be routed the same?
    Any ideas?
    VK SL (Calais Mock)
    Nov 2011
    no idea.... never heard of anything like this.
    Depends on the car.
    VK = Yeah - entirely.
    VL = Nope - epic write off. Crush the entire car and do the world a favour.
    Quote Originally Posted by vkberlina View Post
    253s arent even good for landfill, dont bother,
    VH SS
    May 2009
    Toowoomba, Qld
    my VH used to do this.
    you need to install one way valve in the washer line between the pump and the l/h washer jet. I think Holden still sells them
    something like this
    30mm In Line One Way Washer Valve (10 Pack)
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    ok, so its been a while since i drove mine, but the washer is on the end of the stalk, right? any chance that the wiring is shorting on the column somewhere. its possible that it gets the teensies bit of power, and since the LHS may (or may not) be closer to the pump, it gets enough pressure to squirt that one, but not the other one.
    i dunno man.
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    Again, could be the stalks getting a little old and stiff
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    VH SL/E 5.0
    Nov 2009
    VH SS
    May 2009
    Toowoomba, Qld
    it's nothing as complicated as the switch
    the air passing over the jets (as the car moves) creates a venturi effect, which actually pulls the water through the lines and out the washer jet/s. Mine used to eventually drain the bottle out, until I fitted the valves.
    Holden fitted the one way valves in the later models as standard. Can't remember which model they started with, but I know VN onward have them fitted standard.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    lol I had an easy solution with my VK just dont fill up the bottle
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Found the valve from the the v6 donor car, working a treat!
    Thanks again.
  1. Annoying little problem
    By slutvs in forum General
    Last Post: 02-03-2011, 01:28 AM
  2. bit of a annoying problem
    By Wadeo.. in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-10-2009, 08:56 PM
  3. Very annoying problem
    By Philthy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2006, 04:22 PM
  4. please help - annoying problem
    By =Calais v8= in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-11-2005, 08:11 PM
  5. Annoying Problem...
    By fourstar82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2004, 05:46 PM
