I recently purchased my second VB SL/E Commodore and it needs love, the fuel i put in comes back out brown, and the tank has been dented and sports a patchthe tank had no fuel cap so is rusty inside the filler neck and there is a smell, possibly remains of old fuel turned into varnish? im in a remote area and these cars may as well be non existent up here, haven't seen one since my last one, trying word of mouth around town to find one in a back yard, no luck yet, i have a new recon ww strommy 2 barrel but i am waiting for another tank, the car is luckily (or not) running lpg as well, when revving the motor there is no smoke, but when foot off pedal when engine idles down there is white /grey/blue smoke, is this going to be a big problem? car has the power pack and is quite clean and fairly straight for her age, i would really appreciate all/any help from members here, trying to get her to a level where i can register the old girl, will only vb-vc tanks fit or will vb-vk, vl fit too? kind regards, Darren.
Mate VB to VS tanks will fit. You will need to shorten the filler neck on VN-VS but not a big issue.
blue smoke is usually not a good sign. Could be valve stem seals if it only happens when you rev and then back off the throttle. Might be worth doing a wet & dry compression test.
as mentioned above - VB-VS fuel tanks fit. VN onward will need a minor filler neck mod. Will have to change the electrical connector for your sender unit though as they are different. VL onward (and some VK) have an intank pump. Try running it without hooking up the pump first, but if you have pickup problems, you may have to wire up the pump.
Thanks, i will keep up the search, no smoke while revving only when foot off acc and engine
is winding down, idling it has no smoke.
in a population of ten thousand or so in my town, i have tracked down a vb/vc manual v8 commodore to get a replacement fuel tank and handbrake, doing well not to have to use a freight company to source from another town. Getting her registered and then look at the smoke issue.
Looks like you will be doing valve stem seals.
You can do stem seals without removing the heads...but who know what your guides are like you might as well pick up a spare set of heads and doing them up and just do a swap over
Also before you fire it up blast some carbie cleaner down your fuel lines and some compressed air to try and clean out any crap out of your lines that my be laying in the bottom of them.
cheers
Scott
