Results 1 to 14 of 14
Thread: "k" frame confusion...????
    2003 VY II Calais V8 HBD
    Dec 2008
    Smile "k" frame confusion...????
    Hi There,
    Need some help... project car is originally a VK 6 cyclinder, I am building a blue meanie replica. Is there any difference between 6 cylinder and V8 K frame??? If so, how do you tell the differences??? Have spoken to wreckers but unfortunately still confused.....
    Any help will be appreciated
    GothicKidd's Avatar
    GothicKidd is online now ლ(ಠ益ಠლ
    Series II VR Commodore
    Dec 2010
    South Australia
    Quote Originally Posted by fleetwood33 View Post
    Hi There,
    I do believe that the K-frames are different cause of the weight difference.. So I'd say the K-frame are stronger then the V6kframe. Might have different engine mounting things.
    but noticaeable different.. not sure.
    GothicKidd's Ride
    I push the pedal to the floor, smoke them up and go.
    VH SS
    May 2009
    Toowoomba, Qld
    vn
    Nov 2009
    noble park
    where in the early models is it different from power steer to manual steer? or why wont a manual vk rack fit a vc? VB VC VH diffent brackets that hold the rack between power and no-power steer different?
    Dec 2008
    Talking
    Thanks to all those who replied..... it has been a big help!
    This forum is new to me and very happy with response so far....
    Look forward to talking in the future, no doubt other issue's will come up in my build project! The project car is a Berlina with cerulean interior which is a big help already. Engine will be VT EFI 5.0lt, 5 speed manual with big braking system.
    VH SS
    May 2009
    Toowoomba, Qld
    if you're planning on going EFI 5L, then I'd suggest using a later VN-VS k-frame and steering rack, otherwise you are going to run into steering rack clearance issues with the headers. I've got a VS k-frame in mine
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Quote Originally Posted by the_boozer View Post
    Difference is in the intermediate shaft, different length ( longer shaft on a manual i believe). Also i got told the strut tops are different to increase castor which intern changes the steering geometry slightly. With power steer having more castor which creates more steering effort which is then overcome by the the power steering anyways.
    1979 Commodore 3.3 sedan, 2001 VX Commodore Equipe
    Aug 2009
    Orange NSW
    I tried converting my manual steer VB to a power steer - ran into this issue, power rack simply would not fit on a manual k-frame. Ya see, on all V8 models power steering was a mandatory option. I checked my 1980s parts catalougues and low and behold the 6 (MS) and the 6 (PS)/V8 racks are seperate items each with a different part number. Hope this helps.
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    I have a vh 6 cyl that started out life with a manual steer rack and later I got a power rack off a v8 vh and it bolted straight up to the original k frame with no clearance/fitting dramas and its like that many years later...maybe earlier cars had some differences but vhs dont seem to.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    vt spac vk calais
    Sep 2011
    cranbourne
    Quote Originally Posted by Darren_L View Post
    does it have to be a v8 rack or are the 6's the same?
    VH SS
    May 2009
    Toowoomba, Qld
    Quote Originally Posted by vk_195 View Post
    V8 & V6 racks are the same, just got to find yourself a VL intermediate steering shaft to fit them to the VK
    vt spac vk calais
    Sep 2011
    cranbourne
    1983 VH Commodore SL/E
    Jun 2009
    I used my original k frame and rack. I had a 202 and have a 304 now with CAE Headers. It's a tight fit to get them in but they're sitting comfortably now. I'd go a Vn-Vs kframe and power steering if I had to do it again though to give me more room
    Daniel
    Sent from my iPhone using Tapatalk
    Daniel
    VH SL/E Blue on Silver
    304 Conversion | Custom Headers | Trans-Go Shift Kit | 2800rpm stall | VL Turbo Diff | VL Turbo rear brakes | VT Twin Piston Front Calipers | VT Brake Booster | Slotted Discs F&R | Nolathane bushes.
    VH Vacationer 202, VH SL 185 pack 253
    Feb 2010
    Victoria Pt, Queensland Australia
    I Converted my 202 manual steering to power steering and the Intermediate shaft is shorter than the manual one.VLs have a different powersteering rack than VH so the shaft is different.
  1. Do "police pack" cars have a standard v6 or the "high output" one?
    By Gibson_83 in forum VE Holden Commodore (2006 - ?)
    Last Post: 31-08-2011, 05:42 AM
  2. [LS1] Power "Lag", "Sluggish", "Doesn't feel right"
    By TA 91 WA in forum LSx Development and Modification
    Last Post: 04-12-2010, 07:38 PM
  3. WM Statesman - "Contact Dealer" and "X Service" and Empty fuel gauge issues
    By selimlok in forum VE Holden Commodore (2006 - ?)
    Last Post: 13-11-2010, 07:15 AM
  4. Replies: 13
    Last Post: 26-03-2009, 05:34 PM
  5. "K" frame bolt tension.
    By NPreston in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-12-2008, 01:29 PM
