Results 1 to 6 of 6
Thread: Ignition plug wires.
    VH 304 EFI T5
    May 2009
    Welly, NZ
    Default Ignition plug wires.
    Hey guys, wondering if you could tell me what each wire on the ignition plug means (pink, Violet ect) Really need to know what one is ign. on. Spent ages looking at a wiring diagram, but failed haha. Just trying to wire up my efi 5L in a VH. Thanks Mike
    VY SS
    May 2011
    Auckland
    Have you got a multimeter or a test light?
    One should be live
    Connecting this to each of the other 3 individually. one should make acc, ign and turn starter.
    vn
    Nov 2009
    noble park
    http://forums.justcommodores.com.au/..._v8_wiring.jpg
    from looking at that pink is the ignition , violet is the starter signal,the big red is the main positive about all i can make out of that drawing not real clear or well drawn that 1, you have a good drawing by any chance?
    VH 304 EFI T5
    May 2009
    Welly, NZ
    Nah, not really, only the huge wiring diagram from the workshop manual. So if I was told to wire something to ign. on. Would it be the red or pink one?
    VY SS
    May 2011
    Auckland
    I see what your trying to do now. Based on the above then pink? Definitely not red as that loos like the main feed from the battery.
    Probably easier to do it at the fuse box. Just switch car to ign on find something in the feed that's live and check it goes off with the key. Or you could steal power from cig lighter/headdeck.
    Regardless of where You get find the source, use a relay if you plan to draw much current. Otherwise you'll start blowing fuses.
    VH 304 EFI T5
    May 2009
    Welly, NZ
    Oh sweet, Yeah, I have relays in there. Never thought of using the cig lighter. Will give it another attempt today.
  1. VR BUICK COIL PACK WIRES + and - which wires???
    By H1GHROLLR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-03-2010, 09:32 PM
  2. 4th plug wires how many ? ASAP
    By sycvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-12-2009, 02:30 PM
  3. auto reverse light plug to manual plug
    By The Darkness in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-08-2008, 10:40 PM
  4. Replies: 11
    Last Post: 26-12-2005, 10:48 PM
  5. ignition coil wires for tach hookup
    By tgolds1 in forum Electrical Wiring / Questions
    Last Post: 29-09-2005, 08:06 PM
