Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By Mad84VK
Thread: vk misfiring.
    dumped vk 202 efi calais mok-up.
    Jan 2012
    berri s,a
    Default vk misfiring.
    hi all i need some good advice.. i cracked a valve spring n replaced it checked all other valves etc.. replaced head and car will not run.. ive checked dizzy (replaced), plugs n fuel is good. all vacuum hses on correctly... but it (when i get it running) runs like shit.. as if its running on 2 cylinders or something... any advice will be great..
    vn
    Nov 2009
    noble park
    no vacuum leaks ? I gather the plugs and leads are new and the distributor is good. There's nothing worse than putting parts on just as crappy as the ones you took off (some things I do 3 times for that reason, my oldman makes me dig up shit from the pick a part). I sorta like the vk efi system and have collected a few efi bits of the 3 sets of extractors i have here 2 of them are quiet warped the first set I put on I couldn't get to seal and not leak.
    Jan 2012
    berri s,a
    well yeh i thought this would be easy... i couldnt really tell if theres any vacuum leaks unless its very small leak all seems ok... ive taken head off twice n checked everything (new gaskets each time) n just give up... i dont wanna pay to tow it to a mechanic n then pay a fortune for them to fix it...
    VK SL (Calais Mock)
    Nov 2011
    new leads on it?
    Depends on the car.
    VK = Yeah - entirely.
    VL = Nope - epic write off. Crush the entire car and do the world a favour.
    Quote Originally Posted by vkberlina View Post
    253s arent even good for landfill, dont bother,
    Jan 2012
    berri s,a
    nah same leads they all getting spark etc.. i cant work out what it is...
    vn
    Nov 2009
    noble park
    what the plugs look like? can you tell which cyclinder is missing? maybe a dud injector? (just a guess on the injector bit)
    VK SL (Calais Mock)
    Nov 2011
    i would still change the leads. i had the same problem. the leads where getting sparks but they where still shit. buy some news ones and see how u go?
    Depends on the car.
    Jan 2012
    berri s,a
    ok may try that tomorra... see how it goes.. cheers.
  1. VZ SV6 Misfiring? :(
    By 04sv6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 02-11-2011, 08:17 PM
  2. Misfiring VT Help please
    By Anth0ny1oo1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-02-2011, 11:10 PM
  3. misfiring?
    By vt_nutta in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-03-2007, 06:34 PM
  4. misfiring
    By ciro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2006, 09:02 PM
  5. misfiring?
    By yobbo88 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-09-2006, 09:20 PM
Tags for this Thread
