Hi all ok well this is my first post on here...
Ok I have a VK commodore with a 6 and it has a mC6 the problem is that the box is leaking oil from about 3 places and it has a wine in from 1st to 3rd . I was wondering if there is still any place I Melbourne that does a reco of that box or am I better off just changing it to a aus 4 speed ?
Cheers Darren
Cheers Darren
try Status Engineering in Kilsyth
they would probably be one of few who could help
9725 3611
Smitty...with the VE SSv SII Sportswagon, VK race car and...Kwaka ZX12R
Stick and aussie 4 speed in it, you could pull it out and do seals and run it till it goes bang but they arent a good box, to an M20 or T5 conversion is the way to go
Scott
Wanted 85 VK manual boxey type manual side mirrors not the VL looking ones
what is needed to change the gearbox to a M20 from the MC6??
Cheers Darren
From memory gearbox, tailshaft, selectors. Speedo cable fits, clutch is the same, maybe a throwout bearing.
Scott
HI all well I have change the gearbox to the aus 4 speed, its been fun hm sort of anyway i have now a prob with the cluch cable when the mc6 was instaled the cable was fine but with the m20 its now its loose. question do I have to change the cable to a vh one????
Cheers Darren
Sorry for the bum steer, looks like you will have to do a clutch cable, to get you out of trouble you can make up a spacer to space the cable back from the bellhousing and give the required adjustment and remove the excess play.
A piece of old pipe with a slot cut in it will work, just slide it over the cable when fitted then up to the outer cover for the cable.
Scott
