Results 1 to 7 of 7
Thread: VB VC Body Moulds, Rivets or Double Sided Tape???
    Car
    Jan 2011
    Default VB VC Body Moulds, Rivets or Double Sided Tape???
    If my memory is correct Im pretty sure that the moulds on one of these models were stuck on with a type of double sided tape and the other model had a type of rivet thru the door skin, front guard and rear quarter that had a plastic clip over it and that clip then held the mould in place. Those rivets are a bugger when you want to permanently remove the moulds as you need to grind and weld etc.
    My question here is does anyone know which model used each of these set up`s?
    2007 VZ ACCLAIM WAGON
    Feb 2005
    St Clair
    I think the VC had bonded strips as I remember breaking out the silicon a few years back
    drewVHSS's Avatar
    drewVHSS is offline Donating Member
    '83 VH SS, '79 Malachite Green VB SL '91 VQ Stato
    Apr 2010
    Gosford Central Coast
    ve sv6
    Aug 2010
    vb has pins welded on from factory which use a plastic clip, where vc has double sided tape.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Use double sided tape and sikaflex they will NEVER come off, make sure you use the special primer with it.
    Scott
    Wanted 85 VK manual boxey type manual side mirrors not the VL looking ones
    Car
    Jan 2011
    Quote Originally Posted by glenn l View Post
    Hey thanks for the replies, I thought it was the VC that used the tape Im thinking of building a replica of my old group c in my profile pic and as i wont be using the moulds i would want to start with the model that used the tape as it would make my job a little easier...
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Those pins/studs are spot welded to the panel using a stud gun, You can usually remove them by using a pair of multi grips and twisting them to break the weld .The stud gun was also used for removing dents .You just put a stud in the middle of the dent then use a modified dent puller to pull it. The stud and clip method was phased out when the VC was introduced thats why some panels on the VC had studs and some had double sided tape which was pre heated befor being appplied to the panel .
    I'm only speeding cos i need a poo
  1. anyone know how to get around removing front lip spoiler double tape rip paint
    By SV6.07 in forum VE Holden Commodore (2006 - 2013)
    Last Post: 07-08-2011, 12:54 PM
  2. red vr/vs ss body moulds
    By 51tre vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-10-2010, 09:50 PM
  3. vt body moulds
    By deeelan in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-05-2010, 08:15 AM
  4. sticky double sided tape removal.
    By Goon in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-09-2008, 10:43 PM
  5. Gaffa tape / Duct tape / Race tape
    By Phreddy in forum Jokes/Humour
    Last Post: 11-09-2008, 06:59 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
