Results 1 to 8 of 8
Thread: overheating problem VK
    anthony1020 Guest
    Default overheating problem VK
    car overheats with air con on while dving around town but is fine while free way driving already flushed radiator new waterpump new clutch fan
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    the condensor that is infront of your radiator might be blocked and not letting enough air through to cool the radiator
    VP Executive Series 2
    Nov 2004
    near wollongong
    anthony1020 Guest
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    Quote Originally Posted by anthony1020
    ancillary fan working?
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    anthony1020 Guest
    thermo fan in the front is working thinking of getting bigger fan or twins ?
    Oct 2003
    Leda...Western Australia
    Cool
    These symptoms are normally associated with either a blockage in the fins of the condensor or radiator OR the airflow is low (bad fan airflow).
    Check the fins first (blow out with air rather than flush them with water as this can expand the grass seeds if in the fins). Then make sure that the electric fan is blowing the right way.
    If all of this is OK check the style of the condensor (if it has metal straps on either side is is a serpintine condensor and my need upgrading to a parrallel flow unit. (parrallel units have a pipe at either end)
    If this still fails check that the heater tap is turning off and not causing excessive heat in the A/C system.
    Failing all of the above the Compressor may be worn and might be causing an excessive amount of heat for the cooling system to handle get it checked by a GOOD A/C Tech.
    regards Guy
    120 in a 100 zone.....Sorry officer....I thought you where trying to give my wife back!!!!
    anthony1020 Guest
    Thanks Guy think i will get it checked buy a/c tech. Is there a bigger thermo fan or twin fans available for the VP_VS
  1. 96 VS Overheating Problem
    By FstStig in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-01-2010, 07:22 AM
  2. overheating problem
    By Eliminator in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-02-2009, 02:45 PM
  3. vs overheating problem??
    By joshooaahh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-06-2008, 11:47 PM
  4. Overheating problem.
    By GIMPEESS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-02-2007, 08:14 PM
  5. VC Overheating Problem!!!
    By tarbs in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-04-2006, 10:42 PM
