Results 1 to 9 of 9
Thread: Thrown a wheel bearing?
    synoptica's Avatar
    synoptica is offline Stripping VK - PM me!
    VT povpack wagon!
    Nov 2004
    Hawthorn East, Vic
    Default Thrown a wheel bearing?
    Hey guys,
    Ever since hitting a gutter I've had a tick that seems to come from the front end somewhere, which speeds up with the car's (not engine) speed. Last night on a long drive, the tick developed into a whirring noise, sounding not unlike a jet engine (only quieter) which changes pitch with speed.
    I'm assuming wheel bearing, because it's about the only thing that I can think of that would be making odd noises proportionate to the speed - before I go buying a new set, can anyone confirm this for me?
    Cheers,
    Chris.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Yeah it sounds like a wheel bearing,just be careful replacing it if oyu dont have a press to ress int he new bearing use a soft block of wood to take the shock from the hammer when you bash it in that way you wont damage the outter part of the bearing
    cheers
    Scott
    synoptica's Avatar
    VT povpack wagon!
    Nov 2004
    Hawthorn East, Vic
    Okay - I'm lost - every time I've taken my hubs off, the bearings have just sat on the axle either side of the hub (one behind, one in front) - what am I supposed to be pressing?
    rattattack1313 Guest
    Cool
    There is an inner & an outer bearing race....the race against the shaft (outer race)has to be tapped off..a very tight slide fit......
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    the new inner bearings will need to be pressed on because they arent as thrashed out as your old ones
    Cool
    Presses on, as in, put the new race on, then put the old one on top of it, then tap the OLD one down .....that way you are not distorting the new one at all...once it is on the shaft, use a punch to tap around it evenly......
    VH SL/E
    Jan 2006
    your new wheel bearing kit will come with news cones as well, thats what the bearing runs in. use a small pin punch to hit out, use the old cone to hit the new one in easy as.
    95 VS Vacationer
    Jun 2005
    VIC
    how do you grease the new bearings? i remember somebody telling me to put a clump of bearing grease in your palm, and then there is a way to do it...
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    All i do is using high temp wheel bearing grease work it though the new wheel bearing rollers untill they are completely covered. Next when I press the new bearing outter into the rotor or stub axel adapter (VT brakes) I coat it very generously with grease as well. When fitting the stub adapter or rotor back in with the new bearings keep rotating it as you tighten the nut.
    I use about 2-3 heaped tablespoons of grease, but even at 30-40,000km they still dont need repacking. Although I still check them.
    I reuse the previous split pin at this stage road test the car then pull check/nip up the nut if required then fit the new split pin.
    cheers
    Scott
    cheers
    Scott
  1. Wheel Bearing Noise?
    By chromic in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-11-2007, 02:50 PM
  2. Wheel bearing price?
    By paddyj in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-11-2006, 05:59 PM
  3. wheel bearing plz reply
    By TheStateo in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-07-2006, 12:08 PM
  4. wheel bearing access???
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-10-2005, 12:44 PM
  5. wheel bearing gone?
    By walace in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2005, 11:42 PM
