Results 1 to 12 of 12
Thread: Rear power window cable route
    WH Statesman SeriesII 5.7
    Sep 2004
    Default Rear power window cable route
    Hi all, I installed a set of power windows in my vh on the weekend and fronts went to plan but the rears are not.
    I got the drivers side rear in after a bit of stuffing around but the passenger side wont go on the same way, As if the cable is longer or something.
    What I was wandering is if anyone can tell me the route that the cable need to run on the back windows as I was at it for many hours to no avail. Any help would be greatly appreciated.
    Thank you
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    here you go this should sort you out.
    Attached Thumbnails Attached Thumbnails Rear power window cable route-sm12e-38.jpg
    Sep 2004
    LX SL/R torana, HZ SANDMAN, VH SL/E top 30
    Apr 2009
    BALLARAT
    Just found this old thread after doing a search.
    My rear cable on my VH elec window has popped off and is a complete twisted kinked mess. Have tried fixing it to no avail.
    Just wondering, does anyone know if anyone fixes these? In Vic. Do glass places fix them? Or is there another sort of specialist that can sort it out for me?
    VH SL/E 3.3
    Jan 2011
    BROOKDALE W.A
    Have u pulled urs out and tried to put it back in or is the cable totally stuffed.
    Apr 2009
    BALLARAT
    Quote Originally Posted by magnetvh View Post
    Hi mate.
    can you pull them out?
    I had a look at it and it seems its hard wired with a suage/weld type join to the window at both ends.
    The cables not broken, just completely kinked and knotted.
    When you say pulled it out do you mean take the whole window out? I havent tried that.
    Vk 5LTR
    Oct 2007
    Melbune
    i was lucky to have a bloke at my work thats done it a few times. i spoke to several panel beaters and window mobs and there all didnt wanna touch it
    VH SL/E 3.3
    Jan 2011
    BROOKDALE W.A
    It's not hard wired. Undo the bolts on each side at the bottom of each glass panel.
    I got a detailed picture I'll dig up and post on here for ya. It'll tell u which way to route the wire for each side.
    Iv also posted a thread on here a while back on how to recon the motors and the cable route to.
    I'll get back to ya with some pics
    Apr 2009
    BALLARAT
    Awesom thanks mate. I would appreciate that. I found a diagram on here when searching, which i printed out. That should help.
    But yeah any mort info would be great, as the cars going for engineers check then a roadworthy next week and at the moment theres a block of wood wedged inside the door to stop the window dropping down. Its a good look that....
    Cheers.
    VH SL/E 3.3
    Jan 2011
    BROOKDALE W.A
    This should help. Take the glass out first. Once u got it wound in, get sum1 to put the glass back in and bolt the bottom corners off the glass to the wire. The tension on the cable should b tight but not too tight. A bit play in it like a fan belt.
    Attached Thumbnails Attached Thumbnails Rear power window cable route-image.jpg   Rear power window cable route-image.jpg
    Apr 2009
    BALLARAT
    Mate thats brilliant. thanks so much! Ill have a go at it next week. Cheers for your help.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Those diagrams bring back horrible memories, The first door I did took 4 hours I got pretty good at it by the end of my project, from memory theres lines on the original cables to align to also
    Scott
  1. any1 know how to change the power window cable on vs calais rear door?
    By cxcxcxvcvcvc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-09-2009, 08:38 AM
  2. rear power window
    By Equipe VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-09-2007, 05:53 PM
  3. Rear Door Power Window
    By dazamaz in forum Electrical Wiring / Questions
    Last Post: 09-07-2006, 05:00 PM
  4. VS power rear window cable
    By demenace in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-02-2006, 07:56 PM
  5. WTB: Rear power window switch (VT)
    By be_inspyred in forum Swap / Wanted to Buy / Trade
    Last Post: 17-01-2006, 02:37 PM
