tommytoan
- Nov 9, 2008
- 33
- 0
- 0
- Location
- Perth
- WB One tonner, 202, 4spd
Ive been having trouble trying to get the gauges on my GTS dash (i think its HZ, not sure) to work. Oil and temp do not work, fuel goes straight to max and my tacho stays way to low. I've done a lot of looking around at other threads namely, http://www.#################/holden-v8s/48215-fitting-hz-gts-dash-wb-ute-help-needed-2.html
A person there says that the 12v on this dash gets regulated to 5v for the temp/fuel gauges, I have had the multimeter out and it appears that im getting 12v to the temp and oil.
The other issue is that apparently the temp sensor has different ohms range and that the oil sensor for non GTS dash models are on off sensor hooked up to a light (i got the car with the gts dash so i don't know what my WB had standard)
Now ive tested the resistance on my temp sender and it reads 215 ohms resistance cold. Im not sure if thats high, if the thread I linked is correct then this sender is too high. The oil sender I haven't taken off to check yet partly because im not sure how to check it, what resistance reading am i looking for?
is the tacho supposed to recieve 5v or 12v?
I have attached a few pics showing the supposed voltage regulator that is this thin piece of metal.
any help greatly appreciated!
(i posted this over at aussiev8s but it hasn't come up yet, their forum system is weird :/)
