Results 1 to 3 of 3
Thread: Brake Bleed Nipple Stripped
    VY Calais, WHII Statesman V8, VC L 202
    Feb 2004
    SE Melbourne
    Default Brake Bleed Nipple Stripped
    I was servicing my car yesterday and thought I'd replace the brake fluid. Unfortunately one of the nipples on the rear drum has been stripped by the knucklehead who did the last brake bleed (ie me!!). Is it just a simple case of unscrewing it with a pair of vice grips and screwing in a new one?
    Also, the diff oil plug is stuck firm. Didn't spend much time on it when I couldn't move it with the shifter but access is limited by the panhard rod. Anything else work other than a whack with a hammer to loosen the washer?
    Mark.
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    yeh, just get at the nipple with vicegrips, should be ok with a new one then. diff plug, im not sure, maybe some crc squirted on it or something, just make sure its cleaned off before putting plug back and fresh oil in. otherwise, try and give it a bit of a whack with a screwdriver and hammer (rubber mallet) in the direction of thread to undo it.
    1983 VH SLE SUPERCHARGED 208
    Apr 2004
    Ellenbrook Perth W.A.
    Might as well go and buy a new wheel cylinder from repco/super cheap .... I think they are like $10 or $15 and you need a "Single Hex Socket" and breaker bar to remove the diff plug.. this will ensure no rounding problems like the bleed nipple
  1. bleed nipples
    By Wire in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-04-2007, 07:41 PM
  2. bleed valve
    By jippa3000 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-05-2006, 07:46 PM
  3. Stripped
    By EHVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-03-2006, 09:27 PM
  4. Make it Bleed
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-06-2005, 04:37 PM
  5. VH being stripped
    By Jeff in forum Parts And Other Items For Sale
    Last Post: 13-04-2005, 07:40 PM
