Results 1 to 7 of 7
Thread: Fire extinguisher location
    1982 VH SL/X 6cyl 4spd, soon to be a Mild 253
    Oct 2005
    Port Pirie, South Aust
    Default Fire extinguisher location
    just wondering if i bought a fire extinguisher (just a lil 1) where could i put it in my vh to. where would be the best spot 4 it?(preferably up the front some where) maybe on the passenger side of the console. does it matter if the sun gets to it or is it made for temperatures that high(i mean being used in a fire and all). any help would be great!
    thanks, tukrbox
    SUSPECT's Avatar
    SUSPECT is offline Banned
    SUZUKI GSX-R 1000 k8
    Aug 2005
    adelaide, southern suburbs
    gday mate well i have mine under my drivers seat...but yea any where u can get it really quickly is a good idea i spose.
    Oct 2005
    ok so do u think that it would be/look ok in the passenger side of the console?
    SUSPECT's Avatar
    Aug 2005
    yea thats wear most people put it but i dont think thats the best of ideas cos it draws attention to the wrong sorta persons if u get wat i mean...my 2 cents anyway
    fabz's Avatar
    fabz is offline I Can Do Science Me
    Blown V6 VT commodore 5 speed
    Jul 2005
    In My Car!!
    i had a vk ages ago and had mine behind the center console on the hump in the back floor. So all i had to do was reach around and fit like a glove, looked phat too.
    .:Blown VT V6, DAJ37:.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    In about 1 month I will be fitting one to my VK Look up the CAMS & FIA regulations for you but I would purchase & mount one according to their recommendations, the would have done enough safety etc research to create their regulations.
    Mainly you dont want it coming loose in the event of an accident a 4kg extinguisher could do alot of damage to you. Secondly you should be able to access it from the drivers side seat with minimal movement, incase worstcase your trapped in the car and it catches on fire.
    3 mounting positions I have seen are transmission tunnel behind the seats, passengers side of the transmission tunnel & on the floor infront of the drivers seat.
    cheers
    Scott
    VN Wagon
    Feb 2005
    The car club I'm in require at least a 0.9kg fire extinguisher for certain motorsports events. However make sure you buy one with a metal mounting bracket. The metal bracket also includes the clamp holding the fire extinguisher. Even some of the supermarket fire extinguishers now come with a metal mounting bracket and have a CAMS approval. Check that it has a date stamp and it is "in date". Check that the pressure gauge is not damaged and the pressure reading is okay.
    Technically you need to be able to reach the fire extinguisher from your driver's seat. Most of the guys in the club (WRX) mount them at the base of the passenger seat using a piece of aluminium bar bolt to the front mounting bolts for the seat. While it is a stretch to reach it, it is better than having it come loose and slide under your feet while driving.
    regards
    Pete
  1. VT on Fire
    By nugatory in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-11-2007, 10:04 PM
  2. Where to mount a fire extinguisher....
    By savage1987 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-11-2007, 09:33 PM
  3. Fire
    By Fire in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-02-2007, 11:17 AM
  4. Replies: 17
    Last Post: 09-10-2006, 01:25 PM
  5. useless fire extinguisher transformed
    By hinterland in forum V6 Development And Modification
    Last Post: 22-02-2006, 01:56 PM
