Hi all, I've got a vh and Iwas told that it had a vl diff disk brake in it. I need a new handbrake cable and was wondering wether to get the vh or vl one. Does it matter and is there any difference?
Thanks
Rob.
P.S The nats were a bit quiet this year.
The disc brake diff handbrake cables are the same cable VB-VL just stress to the person you want handbrake cable for a rear disc brake.
The cables are different between drum brake & disc brake. Also try to get one that is coated in rubber or plastic not just plain flexi-steel housing as when the cable rubs on suspension components & the body the housing will wear. The genuine cables used to have a black plastic/rubber cover over them but they are nolonger available from holden.
cheers
Scott
Thanks Scott I'll be able to order one now. It just threw me off that rare spares had a differrrent part number for each cable.
Thanks again
Rob.
Yeah seems strange, but they all use the same handbrake assembly Im running a VL turbo LSD diff in my VK using a VK disc brake handbrake cable.
Just incase they are doing something stupid with them I owuld order one for your model car if its a VH get one for a VH.
cheers
Scott
