G'Day everyone, im new here, great forum glad to be a part of it, ok so i need to replace the head lamp and i followed the instructions in the manual but im not getting anywhere :b: i removed the dust cap, unplugged the little cables then the manual says to rotate the lamp housing anti-clockwise but it wont budge, is there some technique to it? please help, i cant drive by night until its fixed, Thanks
When i replaced the blubs in my headlights i removed the glass off the front of the light. There are clips all way around the front of the light holding the glass on the headlight it self. Unless there is a easy way then i would like to also know. Thats the only way i know of doing it.
Mind you when i did replace them i also gave the inside a wash and clean up so i hit 2 birds with one stone.
Ok Dont pull the light appart to change a globe, basically Donutface your proceedure is correct but the metal globe housing needs to be pushed in before rotating it. It works better if you push down evenly on each side.
If you have further problems I can post a pic for you.
cheers
Scott
Thanks Scott, I didnt know you can remove that part. I will keep that in mind if i ever have to change a bulb again.
Thanks heaps guys, with your help i fixed it. I put in sweet looking blue xenon headlights, apparently safer too...
Safer to blind oncoming me!! lol.
