Hi guys, I'm in the process of rebuilding my 308 out of my vk calais. I've decided to get rid of the rochester carb and have put on 600 vac secondries holley. Is there anyone out there who can tell me where to put all the pollution hoses (cause i need to have them on for roadworthy ) and vacum hoses. a diagram would also help.
CHEERS...![]()
Here you go my one stop VK library http://members.westnet.com.au/scottl...lvac/index.htm
good luck
cheers
scott
Thanks for that info Scott. It helped a real lot.
Cheers Ray...![]()
hey 308commodore
just letting you no you wont be able to get a roady with the holley on unless you get someone to do a shonky roady.
your vk is a full pollution car and no holley was made to pollution specs.
put your quady on 4 the roady and swap them later on.
Greeings.
Never worked out why people insist on taking off Quadrajets and replacing them with Holleys. Just get your Quady overhauled and setup well and you're on your way to having a great Commodore again. Simple folks.
Silver.
the pollution holley was on the motor allready cause the quady that came with the car was totally ratshit, so i'm not about to dump it for the quady. i have allready got a roadworthy from r.a.c.q. with the holley on with no hassells. but thanks anyway for your warning.
cheers![]()
