Results 1 to 2 of 2
Thread: On the tune!
    fitykemp is offline VH SL/E 1981
    81 SL/E
    Aug 2004
    Default On the tune!
    G'day guys, how hard is it to tune a Quadrajet on a 5.0l. Just stripped it and put a kit through it and cleaned it now it has a rough idle. needs to be re-tuned. any help appreciated
    cheers
    james
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Ok first of all are you sure you dont have a vacuum leak?
    Secondly does it do it when its cold & warm or only cold?
    What is your idle speed set to?
    How far did you have it appart?
    Did you have the primary metering jets out? (If so the jets may have been fitten incorrectly or have some crap in them)
    Make sure your fuel strainer doesnt have a heap of crap in it
    When you assembled the carb did you make sure your Intermediate choke shaft lever and fast idle cam are in the correct positions?
    Are your secondaries fully closed and not sticking open slightly?
    Carb Tune, is pretty indepth on these things your gunna have fun
    Float level
    Ok odds are you have the float level wrong
    To adjust the float level you need a float level guage, mine is a Kent Moore its like a thin ruller but the measurements start about 1/2way up.
    With the engine running at idle, and the choke wide open gently insert the guage into the vent slot or hole next to the air cleaner mounting stud.
    The float level should be 9.5mm +/- 1.5mm.
    If the float level is out remove the air horn and adjust the float level.
    Accelerator pump
    Make sure the pump rod is in the inner hole, measure the height of the pump stem from the air cleaner mounting surface to the top of the stem it should be10.4mm if not adjust the pump lever accordingly.
    Theres heaps of choke adjustments but I think the problem is float level or a jet problem
    Failing all that check out your idle system for dirty or gunked up passages.
    Last of all the gaskets you installed my not be sealing properly check the torque on the screws.
    hope this helps
    cheers
    Scott
  1. Tune for C.O.M.E cam
    By Drew4692 in forum V8 Development and Modification
    Last Post: 13-03-2007, 05:32 PM
  2. Tune up!
    By emmtee83 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-06-2006, 04:39 PM
  3. tune up
    By byt in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-09-2005, 05:52 PM
  4. tune up
    Last Post: 02-09-2005, 03:25 PM
  5. Tune Up
    By adsVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-04-2004, 03:33 PM
