Results 1 to 3 of 3
Thread: vk efi computer and what it can handle
    greenvc Guest
    Default vk efi computer and what it can handle
    hi all just trying to find out how much the standard vk efi ecu can handle
    stock = 109kw
    ive added a toyota sc/14 small blower (10lb)
    as well as engine rebuild 060th/big crow cam/roller rockers/yella terra head/extractors/ect ect
    basicly im still waiting on a differant unit to run it properly but im wondering if the standard one would start it and allow me to run the cam and engine in ? anybody played with these
    LH Torana with Ecotec V6
    May 2004
    Tenambit, NSW.
    i've played with plenty of VK EFI systems on similarly modified motors all except for forced induction ....
    the EFI is tunable to get it working with all your mods, but my guess is that its going to run out of fuel map at about 2000-3000rpm and probably flood the motor or lean it right out .... either way its not something i'd recommend doing to a nice fresh motor.
    CRS don't make a kit to fit the SC14 to a VK EFI because the computer can't handle it ....
    when you say big cam, if you mean heaps of overlap and lumpy idle, thats probably not going to be very efficient with the blower, however if you mean big lift and duration with small overlap then you'll be in business!
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Yeah I have had alot to playing on the VK, it will start the car but I advise against it without running an 02 sensor up the exhaust to make sure its not leaning out else you may destroy your nice new engine.
    The problem with the Jettronic injection is that it watched airflow, engine RPM coolant temp and thats about it, it doesnt control the dizzy advance, it cant tell if theres too much advant and cant adjust by much the fuel rate via the injectors.
    Out of interest what aftermarket injection & ignition system do you have planned for it?
    cheers
    Scott
  1. Resetting your computer and trip computer special functions (VT - VX)
    By Darren in forum Holden Commodore How-To's
    Last Post: 19-01-2011, 07:05 PM
  2. trip computer/total distance computer STOPPED!
    By Juzzy21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-01-2007, 10:10 PM
  3. How much can the old vn handle......
    By S Pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-08-2006, 02:00 AM
  4. vt door handle
    By VTPREDATOR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-03-2006, 12:21 PM
  5. new door handle
    By rekless driver in forum General
    Last Post: 31-01-2006, 09:35 PM
