Results 1 to 19 of 19
Thread: vk dash not working
    Owen Guest
    Default vk dash not working
    i hva ejust bought a vk calais and the dash doesnt work
    i am wondering if ne1 could help me with it
    its an electronic dash
    cheers
    synoptica's Avatar
    synoptica is offline Stripping VK - PM me!
    VT povpack wagon!
    Nov 2004
    Hawthorn East, Vic
    Probably going to need to elaborate a bit more than that dude.... 'not working' doesn't help much. As in, it doesn't turn on at all?
    The VK electronic dashes aren't reknowned for their reliability, sadly - I'm fortunate enough to have scored one manufacured in 1996 (!!!) so I'm hoping it'll be a decent quality one (when I get around to fitting it)
    the lightning
    Jun 2005
    under the Southern Cross
    Quote Originally Posted by Owen
    cheers
    first thing i would do is to check that the round harness that plugs in the back has a good electrical connection to the dash as this harness contains the power wires from the ignition to the power supply in the dash.
    if you need to jiggle it and it works but then fails to work after turning ignition off then on again I'd say that the power supply may be knackered... thats what the problem with mine was anyway.
    these dudes can help you if you're located in melbourne....
    Automotive Instrument Repairs Geoff Newson 9561 2366 Mulgrave
    Owen Guest
    VKnVLCalais Guest
    does ur interior light work??? if not its prolly ur fuse, number 9 in fact, and its a 15amper.
    Owen Guest
    nah all my lights inside work just the dash
    it has no lights no nothin on it at all and i havew changed ALL the fuses in the car and no change
    kel_VK_Calais Guest
    VK Electronic dashes SUCK...mine's stuffed too....tells me i'm outta fuel all the time, tells me I'm low on coolant all the time, speedo is WAAAAAAY out...hate the bloody things, they're useless. Anyone know of one that actually works? Brissy area....
    And synoptica, how's you manage to score a new one?!
    synoptica's Avatar
    VT povpack wagon!
    Nov 2004
    Hawthorn East, Vic
    phat_com's Avatar
    phat_com is offline VR IS A BEAST WITH NEW V6
    VR s2 Acclaim/VK IS GONE :(
    Jan 2006
    Tuggers (da hood),ACT
    sweet as
    i wish i could find a good vk calais (want a 2 tone one)
    all the ones i find have been rear ended or rust buckets
    any 1 know a good one in act/nsw?
    has 2 be 2 tone or silver and 2 grand max
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    lol lookin for similar thing here in SA.... actually been looking interstate too.... clean, rust free, Silver Calais with cerulean interior. Turns out pretty hard to find
    D.
    ovk338 Guest
    its a common thing with the dash as i had the same problem to but i got a good one from the wreckers (Heat and old age stuffs them up)
    Owen Guest
    NORTI's Avatar
    May 2004
    well guys i bought my well workin 1 off ebay for $60
    nice, nice!
    D.
    VK Calais
    Jul 2009
    NORTI's Avatar
    May 2004
    They are VDO, so I assume any VDO repairer can fix them.
    Retro, what did you mean by 're-done'?
  16. #16
    VK Calais
    Jul 2009
    Norti, Yeah sorry wasnt very specific, as in getting the Dashes re conditioned so they everything works as it should my clock doesnt work, avg fuel and Avg Speed doesnt work pretty much all the lil read outs on the far LHS of the Digi Dash just wondering if Auto Elecs have a grip on them or their just a nuisance to live with
  17. #17
    NORTI's Avatar
    May 2004
    most of the time the dash isint the bit that fails, its more that the sensors are ****ed.
  18. #18
    VK Calais
    Oct 2009
    VK Calais
    Oct 2009
    I found out a few checks you can do yourself.
    On the transducer the smaller cylindrical metal part that screws into the module that is screwed to the shock tower. (Note you also screw the speedo cable into the module that you screw to the fire shock tower.)
    The transducer has 3 wires, a Pulse wire, a Ground Wire and a Ignition(power) wire.
    On the ground wire with the ignition turned off place the black probe of your multimeter(set to test 20 ohms) on the negative battery terminal and the positive to the ground wire, your resistance should be less than 20 ohms or you are not getting a good enough ground.
    If not clean up your contacts back to ground.
    On the Ignition (power) with the ignition on test the DC volts to make sure you are getting good voltage.
    On the Pulse wire have your red probe on this wire and the black to ground and rotate the the end of the transducer fitting(like end of speedo cable square section) slowly the voltage should change from 0 to 5 volts and back again as you rotate the end.
    Also you can attach the end of this to an electric drill and rotate it at speed to see if your speedo works for a check.
    Hope this helps someone.
    Cheers,
    Tim
  1. Help Dash Lights Not Working
    By saint_matrix in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-11-2009, 10:24 PM
  2. Done all the checks but dash lights still not working
    By scoots in forum Electrical Wiring / Questions
    Last Post: 30-04-2007, 01:52 AM
  3. Dash display not working
    By Hgprem01 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-10-2006, 03:31 PM
  4. vh lights on dash not working
    By scolari in forum Electrical Wiring / Questions
    Last Post: 31-01-2006, 03:27 PM
  5. dash light not working on VC
    By jacob1986 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-01-2006, 12:11 PM
