Results 1 to 6 of 6
Thread: Turbo 700
    VH SL/E 4.2
    Mar 2005
    Cobden, Victoria
    Question Turbo 700
    I have heard of someone putting a Turbo 700 gearbox behind a 308, and i am wanting to put one in my commodore behind a 253. Has anyone had any experience with this issue and if so can i have all the info neccesary to do the conversion...
    Cheers...
    Boonz's Avatar
    Boonz is online now the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    the bellhousing on your engine needs to be a turbo pattern to fit..... 253's and some 308's dont have them so a change of bellhousing might work if your keen on the box
    VH Wagon
    Sep 2010
    You will need to buy an adaptor kit from Castlemaine Rod shop or a speed shop. It consists of a spacer plate and a set of special machined eccentric bushes and studs. You will have to probably customise your tailshaft, speedo cable, trans cross member and t-bar shifter. I don't think it is a bad idea as a decent 253 with a 4 speed auto and the right gearing would be a good set up.
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Either the adapter plate, or u could get ur block redrilled to turbo pattern. Prolly a bit overkill as the whole motor has to be stripped down completely, but it can be done. Either that or weld up the trimatic holes, then get a ruler, pencil, drill and tap/die set out and go ur hardest.....but don't coz it's dodgy as fark, but I do know someone who has done it and they rekon it worked. The adapter plate way is the easiest!
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    DANNY8's Avatar
    Apr 2004
    Haha didn't even notice that!
  1. Super Charger, Twin Turbo Or Single Turbo On My Vx Need Suggestions
    By GMHG3N in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-09-2009, 11:38 PM
  2. GROUP BUY TURBO - GENUINE GARRETT TURBO GT35/40R 700Bhp
    By GTS1963 in forum Parts And Other Items For Sale
    Last Post: 21-12-2006, 12:14 PM
  3. twin turbo ecotec, turbo selection?
    By jenkos_vl in forum V6 Development And Modification
    Last Post: 08-11-2005, 12:03 PM
  4. Confused and unsure...turbo/supercharger/stock turbo?
    By venomous in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-07-2005, 09:51 PM
