Results 1 to 2 of 2
Thread: redlinetoker 2 install????
    smokemachine Guest
    Default redlinetoker 2 install????
    just got a red line toker 2, when i took the manifold off i notised that there were 2 holes on ether side of the stock one that are not on the redline. is this going to be a problem. also dose any one have one on ther car as id like to know if they inprove them much.
    Sep 2005
    Depends on the heads you have, the early ones just have the one bolt in the middle, later on they went to the type with the two bolts in the middle. Soyour head uses the two bolts in the middle? Does the redline manifold have blank bits that you can drill to put the two bolts in? Some manifolds have it blanked in the middle so you can drill to suit the heads you have.
  1. VN Install
    By draco386 in forum Car Audio
    Last Post: 05-11-2007, 01:20 PM
  2. install vx ecu into vs
    By Chuckster in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2007, 11:53 PM
  3. Need Help with Install
    By azzfox in forum Car Audio
    Last Post: 30-06-2006, 10:28 PM
  4. VZ Install
    By SV6 in forum Car Audio
    Last Post: 12-02-2006, 04:25 PM
  5. how to install ac in a VL
    By gambit120 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-10-2004, 11:36 PM
