Results 1 to 7 of 7
Thread: blue/black block
    VY 'S' Pack '03
    Jul 2005
    Tanjil, VIC
    Default blue/black block
    what are the (if any) differences b/w a bare black and blue block???
    CalaisVKiller Guest
    there are a lot of differences run a search and find articles but mostly its between the cylinder heads and water jackets not lining up (i think) if its a vk get another black motor so you dont have any dramas
    VE SII Sv6 Manual
    Aug 2004
    Blue black heads are interchangable.
    only the red had different water jacket ports.
    Some minor casting differences for the air pump mounts that i've seen. thats about it.
    GMH 72 Guest
    On the 6 cyl Black engines the oil flow was changed in the timing gear area & also the timing cover has a different casting to allow for the new oil redirection.
    If i remember correctly this change only happened with the EFI engines only & not the EST, don't quote me on that but a fact is that there was a change in the oil flow in the timing gear area & a different timing cover casting.
    VE SII Sv6 Manual
    Aug 2004
    That oil flow change is true for both carby and efi motors but is only in the timing cover, there isn't any difference in the block.
    The timing gear oiler is still the same, but the cover has a shield around the cam gear to carry the oil around an onto boht cam and crank gear.
    VY 'S' Pack '03
    Jul 2005
    Tanjil, VIC
    ok, then and ive just found a virign bore black block so i don't need to worry bout the diff any more thanx anyway
    EcotecVK is offline Building it now...!
    VK EXEC 3.8L - VB SL/E 4.2L3 - VC SL/E 5L 4 spd
    Feb 2006
    Earth
    Uhm, my VK has a 202 Black in it, i blew the Nylon timing gear and broke trhe cover trying to replace it. It nows has one from a 202 Red on it. and it fits perfectly?!?!
    VK SL with VS Ecotec V6 and 5 speed Conversion (Ex 202 and 4 speed)
    VB SL/E 253 auto - Written off by blind old bat who can't see stop signs.
    VC SK 5L 4 speed manual, VL Turbo Diff - (another) blown aussie - intention is for Chev, 6 speed and ford 9 inch, and donate the VL Turbo diff to the VK.
  1. blue head on black block 6 cyl
    By CaptainKen in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 17-10-2007, 11:00 PM
  2. Red head black block
    By lenie33 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-10-2007, 02:49 PM
  3. How much would a Yella Terra head for for a 3.3 EFI black block
    By A-TEAM AUTOMOTIVE in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-09-2006, 09:23 PM
  4. blue 202 head on red block?
    By potshots007 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-05-2006, 08:35 PM
  5. Black Or Blue?
    By Kim in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-02-2004, 08:54 PM
