Results 1 to 10 of 10
Thread: gearbox oil, plezzzz ????
    StanTheFrog Guest
    Default gearbox oil, plezzzz ????
    hey hi again,
    well i figured out what is my problem i think...i new in cars, be gentle...thx
    So i have a gearbox problem (automatic), i think i dont have enough oil in it...
    well do you know where to put it, or do i need to go to a mechanic ???
    i have a Holden commodore SL sedan 1981
    thanks you very much for the answers
    VY Calais, WHII Statesman V8, VC L 202
    Feb 2004
    SE Melbourne
    We all have to start somewhere, it's great that you're showing an interest in your car. You'll like it here, everyone will take it easy on you.
    Any mechanic can top up the fluid for you, but I suggest you save yourself some dollars and increase your car knowledge.
    The automatic uses transmission fluid (yes, I know I'm being pedantic!!) but it's totally different to the oil your engine uses. Your automatic is known as the Trimatic (or more commonly the Traumatic!!). The autos don't like being overfilled, so you need to make sure you're reading the level at the correct temperature. Assuming you're reading the dipstick correctly: after a drive with the engine hot, still running and in Park. If the fluid's low it's just a case of pouring new fluid down the dipstick tube to the correct level. I can't remember what fluid the trimatic uses, if no-one else posts here in the meantime I'll check when I get home but you need to use exactly what is specified. Remember to fill it very slowly and check it continually - don't overfill it.
    Mark.
    P.S. Love you username.
    StanTheFrog Guest
    hey thx man for the answer,
    my username is because im french and im a backpacker squatting in melbourne...lol...i bought this car like 3 weeks ago in sydney for 1200bucks and was running perfectly for the 1200km i did with it...but start to make real strange things with the transmission...
    now the R doesnt work (hopfully im park in a parking lot)...
    So i checked everything with a friend and we deduced that was the transmission fluid level which was a little bit low...
    synoptica's Avatar
    synoptica is offline Stripping VK - PM me!
    VT povpack wagon!
    Nov 2004
    Hawthorn East, Vic
    Go to your local supermarket and pick up a bottle of DEXRON III ATF. It's what you want. Should come in 1L bottles from Woolworths/Safeway...
    StanTheFrog Guest
    synoptica's Avatar
    VT povpack wagon!
    Nov 2004
    Hawthorn East, Vic
    Down the same hole you check it through
    So whaddya think of AU cars? Better than a Renault? :P
    Wheelz60 Guest
    The Trans fluid is poured down the transmission dipstick hole.
    Its just at the back of the engine compartment on the drivers side.
    StanTheFrog Guest
    thx guys, so same hole as i checked...thx
    well AU cars are good except when it is old...if this is not the fluid my car is dead then...lol...
    but good cars anyway, i wish i could find a good cheap holden commodore...i have a beautiful pegeot 206 at home, wish i could have it here to travel, lol...
    Now holden is opel, lol...
    synoptica's Avatar
    VT povpack wagon!
    Nov 2004
    Hawthorn East, Vic
    Get yourself an Opel Senator or Rekord :P
    Different engines, otherwise almost identical
    StanTheFrog Guest
    ok i will buy one of those...lol
    i let you know about my car...
  1. Gearbox?
    By diego in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 29-09-2007, 07:16 PM
  2. New Gearbox!
    By Torquen in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-08-2007, 12:23 AM
  3. vs manual gearbox / rebuilt strengthed auto gearbox
    By petezor in forum Swap / Wanted to Buy / Trade
    Last Post: 14-12-2006, 07:51 PM
  4. VB gearbox into VH
    By V3N0M in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-07-2006, 09:35 PM
  5. need a gearbox....
    By Lano in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2005, 05:12 PM
