Results 1 to 6 of 6
Thread: VH Interior
    CommodoreBoi Guest
    Default VH Interior
    Hey All, just a quick question if anybody knows. would a vh interior fit into a vk?? thanks
    VS Commodore Omega
    Apr 2005
    Everything should go straight in (seats) but the door trims depend on where the interior lock is located (top or side) and if the windows are electric or winder, if they're the same then they should go straight in
    This isn't only for VH -> VK but for all cars VB to VL (except the passenger side seat on the VL because the cat causes a lump under the seat in the floor pan meaning different rail/mount assemblies)
    Hopefully this has helped
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    The headlinning won't fit due to the rear "C" pillers
    VS Commodore Omega
    Apr 2005
    Ah that was well! The VB -> VH should have the same roof lining, because they added that extra window in the VK -> VL.. they should be interchangable as the VB -> VH
    How could I forget the C pillar extra window *embarassed*
    Holden VH SLE 253
    Dec 2005
    Another Space Filler
    If you want to change the dash also its not hard to do. The only thing you have to do is change the wiring loom to suit the VH dash and use your heater controls from your VK. Thats if you want to change it.
    isaac_2jz Guest
    id just buy a scrapped vn-vr dash and put in, looks ma,d some other bloke has done on here before
  1. Interior kits or changing Interior
    By iRiot in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-11-2011, 08:54 AM
  2. Replies: 7
    Last Post: 27-02-2007, 03:55 PM
  3. Interior
    By wes_v8 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-10-2006, 08:24 PM
  4. vn-vs interior
    By stocky in forum Swap / Wanted to Buy / Trade
    Last Post: 11-10-2005, 07:19 PM
  5. vh sle interior
    By 308commodore in forum Parts And Other Items For Sale
    Last Post: 24-08-2005, 02:41 PM
