Results 1 to 5 of 5
Thread: strange engine problems
    pingin Guest
    Question strange engine problems
    I have just recently got a v.k efi 202, back on the road after it's near death, but am having a few teething problems, when it starts cold it flutuates between 300-800 rpm and a cloud of blue/white smoke will blow out the exhaust, also i only seem to be getting 5 k.m out of a litre, thats not even really pushing it hard, i have recently changed the fuel tank, and fuel pump,
    I am thinking it might just be the injectors but not to sure!!
    can anyone help me please, fuel prices are killing me...
    cheers.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    What fuel pressure is the car running, prior to start, idle & fast idle?
    There is a hose that runs from the rocker cover to your airbox in the airbox there is a little foam filter is it wet with oil?
    Failing that test your airflow meter and make sure its within spec
    cheers
    Scott
    Feng-Shui Guest
    Quote Originally Posted by vkberlina
    What does that hose do, i can't seem to find it in my engine manual? On mine the hose off the rocker cover is cut off and there is now a hole in the side of the airbox.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    ok it is a crank case ventilation hose, the oil fumes from the engine into the airbox to be burnt but the engine.
    Now if the engine has blow by around the rings oil will be forced down the tube into the airbox. basically a tell tale sign the engine is stuffed and it needs a rebuild
    cheers
    Scott
    Feng-Shui Guest
    Ok then, i guess we should connect that before we take it in for a rwc. Thanks mate!
  1. Engine Problems
    By Holmez in forum V8 Development and Modification
    Last Post: 10-10-2007, 12:25 PM
  2. strange engine noise
    By andyli in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2007, 08:42 AM
  3. VS V6 Engine Problems
    By Rusty's VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-05-2006, 12:51 AM
  4. Strange problems! Please help
    By chirpies in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-02-2006, 12:03 AM
  5. Help VS engine problems
    By seabass in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-10-2005, 07:31 PM
