Results 1 to 4 of 4
Thread: VB-K 8 bolt lsd center Townsville qld
    DryftKult's Avatar
    DryftKult is offline Tinker Whore
    vn berlina
    Jan 2006
    Townsville Qld
    Default WTB: VB-K 8 bolt lsd center
    I'm desperatly seeking a 178mm 8 bolt slaisbury lsd centre in either 3.55, 3.66, or 3.98 ratio's.
    needs to be in servicable or repairable condition.
    DryftKult's Avatar
    vn berlina
    Jan 2006
    Townsville Qld
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Mate they would be the hardest to find. It would be better if you went to a wrecker, see if they have a 10 bolt LSD commodore diff or a VL LSD diff
    Actually i don't think there was an 8 bolt LSD diff in those ratios.
    DryftKult's Avatar
    vn berlina
    Jan 2006
    Townsville Qld
    unfortunatly the borg warner diff isn't an option as the centre in question is going into a gemini housing, the salsbury differentials in the gemini are just shortened versions of the vb-k commodore 4&6 cylinder unit.
    they are available in those ratio's as a bloke who builds these combinations often for gemini's requires one of these ratios and the others use a different size hat and won't fit the gemini ring gear.
  1. Townsville
    By blue alliance in forum The Pub
    Last Post: 30-12-2008, 02:35 PM
  2. WTB or Swap 10 bolt open center any ratio
    By Bilbs in forum Swap / Wanted to Buy / Trade
    Last Post: 17-12-2007, 09:40 PM
  3. Who Live's In Townsville.
    By CHANDLC in forum The Pub
    Last Post: 01-11-2006, 02:30 PM
  4. TAS to Townsville which would you drive?
    By petroleum in forum The Pub
    Last Post: 13-09-2006, 12:59 PM
