Results 1 to 13 of 13
Thread: VK V6 Engine conversion and Diff
    WH II Statesman GEN III
    Jun 2005
    Dusty Dubbo
    Default VK V6 Engine conversion and Diff
    Does any one know what is involved in putting a VP V6 engine into a VK
    and also a VN-VP disc brake diff.
    any information would be greatly appreciated
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    What you need is the VN-VP engine K frame to fit a V6 in the VK, need a auto electric to wire up everything. The diff can fit but will be way to long, a VL turbo diff would be better
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    A V6 will bolt into the standard commodore K Frame, you dont need to change K frame unless you want to run if you want to use the VN or later rack. The mounting points are different to mount the rack.
    There are possible issues here that are being looked into by engineers with using the the VN or later K frame and rack apparently it may adversly affect the steering geometry.
    The wire up isnt very hard anyone with a reasonable electrics knowledge can wire it up, as long as you can read a wiring diagram.
    You will need the computer, wiring harness, under bonnet fuse box. You will need to get your tacho recalibrated to suit the V6.
    You have 2 options for a radiator, change the inlet & outlets on a normal VK one to suit the V6 or change the radiator tie bar and run the V6 radiator.
    If you are using the 4 speed auto you will need to modify your transmission tunnel, if your using a 5 speed you will need a different gearbox mount & cross member.
    You will need to modify a tailshaft to suit make sure you get the output shaft for the gearbox.
    Diff wise the VN later diffs are too wide, definitely go a 78 series Borgwarner, I suggest a VL V8 3.08 if your running the auto any other ratio you will have speedo accuracy problems without a ratio box. If its a T5 the VL turbo 3.45:1 diff will be sweet.
    cheers
    Scott
    VK Se2 V6
    Sep 2003
    Country South.Australia
    EcotecVK is offline Building it now...!
    VK EXEC 3.8L - VB SL/E 4.2L3 - VC SL/E 5L 4 spd
    Feb 2006
    Earth
    www.V6conversions.com.au
    www.ogspeedshop.com.au
    these guys can help, and alot of others can find bits for you. Rod hatfield makes K framesthat are able to be bolted straight in and passed.
    If you are in adelaide, i have heard that Pheonix mechanical can do it.
    I am going to eventually do this to my VK, but with a VS ecotec (I hope anyway) other sites to look at are sites where these conversions have been done:
    www.v6vk.tk
    www.ecotecvb.tk.
    Enjoy!
    VK SL with VS Ecotec V6 and 5 speed Conversion (Ex 202 and 4 speed)
    VB SL/E 253 auto - Written off by blind old bat who can't see stop signs.
    VC SK 5L 4 speed manual, VL Turbo Diff - (another) blown aussie - intention is for Chev, 6 speed and ford 9 inch, and donate the VL Turbo diff to the VK.
    fcholden Guest
    95 VS Vacationer
    Jun 2005
    VIC
    You could try CRS (Castlemaine rod shop), they have all the stuff for the conversion
    vs spac, pantha mica, vy ss rims
    Aug 2005
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    Quote Originally Posted by wikid_sticks
    just did a search on google.. and found this.
    http://www.v6vk.tk/
    as posted above.
    D.
    VK Se2 V6
    Sep 2003
    1981 3.8L VC Commodore
    Jan 2007
    braidwood
    the vn diffs aren't too wide...mine fits snugg...the only thing is the panhard rod needs to be pulled over about half an inch...the wiring is ok...only issue i have with mine is the dash lights stay on atm all the time lol....ignition switch is faulty...the speedo from the vn can be modified to fit in the vk cluster its all good
    3.8 Litre Vc Commodore-OTRCAI, no restriction exhaust system from the headers back, reprogrammed ECU-200 Kilos lighter than the VR that the motor came out of :w00t Thats Gold!
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    vb sle vn v6 drive line
    Jun 2010
    lara geelong vic
    all this has helped me, cheer but iv got a vb sle and chuckign vn v6 and trans in it tomorrow how would i go about moving the batary holder from one side to other side? or would it be easyer to pay auto electrition or do it myself? but then again ill need engineers cert cause its not regoed. or is there an easyer way around it. could someone give advice?
  1. diff conversion
    By vkhawkey in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-01-2008, 02:04 PM
  2. Ford 9 inch diff conversion
    By craigvk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-10-2006, 04:43 PM
  3. vr to vb diff conversion
    By oldenvb in forum General Discussion
    Last Post: 09-05-2006, 02:57 AM
  4. Engine Conversion
    By anton1o in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-03-2006, 10:14 PM
  5. VLT diff or disc conversion
    By Snowfox in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-10-2004, 06:16 PM
