righto first thing to do is pull out front and rear windscreens, rubber and all. Now take off the centre dome light, just the chrome surround should do.
Next is remove all door pinch welds, the bit that goes around where the door shuts. Now work from the back to the front. Slowly pull the velour from edges where the rear window goes, plus the rear C pillers too and pull away very gentley. Now you will stop near some wire, called listing wires, these just clip in. Pull them slowly towards the rear and they should come out. Repeat this untill you get to the front. For the front pull the velour away from the front windscreen edges gentley. Now it should be done.
