Results 1 to 4 of 4
Thread: sterring wheel troubles
    POVRTY's Avatar
    POVRTY is offline building 5L VB TH 400
    VE SSV 6SPD WGN
    Dec 2005
    taree nsw
    Question sterring wheel troubles
    i just bought a 308 stroker and it hammers. when i give it some the steering wheel and boss kit come out towards me. i can still steer. it feels like the steering shaft is moving. it only moves about an inch or so. can any one who has had this problem tell me what they did to fix this.
    HDT VK SS
    Feb 2006
    Quote Originally Posted by POVRTY
    Take Steering wheel of and it should be the main nut that bolts the boss. Happens from gradual vibration and nut becomes loose. Happened to me a few years ago... hope this helps
    com3800 Guest
    Talking Steering
    yer mate, other than checking the main nut and the locking nut, also check that the circlip is still there !!! Easiest way to tell is remove the nuts and the steering wheel, If you can move the shaft in and out by hand then that is one cause of that problem also... Cheers
    VH SL/E 1982 commodore/WB ute x2 VP commodore
    Nov 2005
    Cairns Far Nth Qld
    Also cheek u main clamp on your streeing rack as that might of come lose as well couse they are a tapped bolt it might be threaded
    Shawn Johnston
    Cairns Far Nth Qld
    Mobile:0488 530 009
    MSN: sbj_security@hotmail.com
  1. URGENT - Steering Wheel Troubles!
    By jozza87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-06-2009, 09:27 PM
  2. playstation with 115 games,sterring wheel,gun,dvd adaptor ,2 controllers,
    By vrjay in forum Parts And Other Items For Sale
    Last Post: 30-03-2006, 08:10 AM
  3. sterring wheel troubles
    By POVRTY in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-02-2006, 02:01 PM
  4. Sterring Wheel
    By AirStrike in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-01-2004, 06:02 PM
