Page 1 of 2 12 LastLast
Results 1 to 25 of 36
Thread: Vk Brake Upgrade
    WH II Statesman GEN III
    Jun 2005
    Dusty Dubbo
    Default Vk Brake Upgrade
    I just wanted to know what is the best brake upgrade for a VK commodore,
    would it be possible to fit VN - VP brake rotors and calipers to the VK and also brake booster and master cylinder.
    or would I have to replace the entire strut tower and if so would it fit ?
    also I wanted to know about a disc brake diff, I have been told a VN-VP diff is too wide, and was told to fit a VL unit to the vehicle. were the VL diff centres off set and if so does this affect fitting it to the VK.
    synoptica's Avatar
    synoptica is offline Stripping VK - PM me!
    VT povpack wagon!
    Nov 2004
    Hawthorn East, Vic
    Okay - you have a couple of realistic options.
    Option 1 - VT twin-spot uprgade. Expensive, but will pull up VERY well. Probably overkill for something sub-150kw.
    Option 2 - VL Turbo (VN V8 and VS 6-cyl are also the same) upgrade. Quite cheap (I have drilled and slotted VLT/VN V8 etc spec rotors on the front, with calipers to match). Was around $190 for the upgrade - rotors were 2ndhand with about 5000km on them, calipers were $20 each from the wrecker (normally at least double that, wrecker obviously didn't realise their value - pays to shop around!). A very effective upgrade - only problem is you need minimum 15" rims to run them.
    As for rear end - I'm soon upgrading to a stock VK disc rear end. You could go one step further and go the ventillated rear discs like vkberlina did - but I think he sunk a fair amount of money into that , and he's pushing a few kW so it's probably worthwhile for him.
    VLT front spec and stock rear discs are the way to go I reckon, as far as bang for your buck goes, at least
    edit: to directly answer your question - strut doesn't need changing, just the rotors. VN/VP S1 V6 brakes are the same spec as VK ones, get VN/VP V8's or VN S2 V6 brakes. VL Turbo and V8 brakes again are the same. Don't ask for VL Turbo brakes at your wrecker - he'll charge you twice as much for them! VN V8's the way to go, same shit, different label. You won't need a new master cyl or booster or anything - until you fit rear discs.
    I know you can fit a VN diff - you just have to have the right offset wheels. I have VS rims on mine, thus it should be fine. Don't quote me on this though! If anyone knows better then feel free to correct me.
    Jun 2005
    Dusty Dubbo
    just a question you say that the strut towers don't need changing, this means that the above mentioned calipers will bolt directly to the original VK strut tower, its just that if I am to fit a larger rotors won't the mounting holes haveto be higher on the strut tower
    synoptica's Avatar
    VT povpack wagon!
    Nov 2004
    Hawthorn East, Vic
    Bolts straight on - if you fit larger rotors, you need larger calipers to clear them - but the strut itself remained the same from the VB-VP on all models
    Jun 2005
    Dusty Dubbo
    Owen Guest
    im lucky i bought my vk calais and it has the vl turbo rotors on her and bl00dy hell they pull me up VERY quickly svaed my ass a few times
    VE SII Sv6 Manual
    Aug 2004
    VT calipers bolt directly on to the struts, the only things required are conversion hubs, as the VT hubs are not integrated with the rotor. and long brake lines. VT flexi hose is to short. And recommended 1 inch master.
    I'm running the VT front brakes on my VH with and EFI 202 pushing 108 rwkw and they work an absolute treat
    insan3 Guest
    Quote Originally Posted by synoptica
    my vk has vn v8 drilled an slotted discs front an rear,vn calipers all round...alll bolted straight on...as for the diff,thats in there too..but..i had to have it shortend 35mm each side.
    just my 2 cents from sheep land
    baa!!!!!!!!!!!!!!!
    Previously- VT V6 5Speed, now a VL Exec
    Oct 2008
    Central coast NSW
    Default Help!
    Hi guys, I want a disc rear end for my VL, but the price of VL turbo and VL V8 diffs are ridiculous, will a VB-VK disc rear end fit in? and any info on the VN option wouldbe great, like if i put a decent sized wheel on will i smash my rear guards to hell.
    cheers
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    VB-VK all use the Salisbury diff, with the exception of the VK which had a few come out with Borg Warners (which ur VL would have).
    I think the best option would be to get a disc setup off a VN and put it onto ur VL diff, apparently that works. The VN diff is wider then the VL diff, so not the best idea chuckin the whole VN diff in.
    VK calais
    May 2006
    cranbourne
    Quote Originally Posted by tycho89 View Post
    cheers
    if you are only after a rear diff with rotors i have one in my shed off a vk calais, only thing is that it is non LSD
    twitch666 is offline tricked vk
    vk executive
    Nov 2008
    cairns
    hey man yeah you can fit a vl unit underneath it doesnt matter the it sits a lil bit offset i just done it to my vk put a full vl diff and brake setup in mine as well as motor and box. it lil bit tight but it will work as long as you got the right tools parts and know how or the mates with the know how.
    vk executive
    Nov 2008
    cairns
    VY 1 Maloo
    Feb 2006
    My efi 5litre VK wagon has just undergone the VT brake conversion and am in the process of modifying and fitting a VY booster and master cylinder so the pedal won't be spongy. Not that hard to do and should keep the pedal the way I want it.
  15. #15
    VK 3.3i, V6 VL in Production
    Apr 2006
    Bathurst NSW
    Quote Originally Posted by synoptica View Post
    I went to 290mm ventilated rotors and used the same calipers and pads. You just need VP-VS caliper brackets and they fit up good.
  16. #16
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    read this in regards to the diff questions diff, all you need to know
    but to sumerise, the VL BW diff is 12mm wider then the salisbury diffs used in the earlier models. the VN diff is 40mm wider then the VL diff (or 52mm wider then the salisbury). although the diffs are wider, they are still central to the chassis and don't offset the wheels to one side. if the wheels are offset due to lowering then you need to use a adjustable panhard rod to center the diff under the chassis.
    also note that only the VLT (3.45:1) and V8 (3.08:1) VL diffs had 4 spider centers, the 6 cyl VL's only had 2 spider centers with 25spline axles and these aren't that strong
    Body by Holden, Soul by Brock
    the Legend will live forever
  17. #17
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Can we confirm something, as a few different things have been mentioned.
    Talking about only upgrading the front brakes for now.
    Going from standard VK Brakes to VN V8 (290mm) brakes, you only need to change the rotor, caliper, and the pads, or do you need to change the caliper brackets aswell?
    And you can use the standard VK Booster and master no worries?
  18. #18
    Apr 2006
    Auckland NZ
    Quote Originally Posted by Tom_1569 View Post
    you would need to change the complete caliper(with bracket). it's the bracket that the correctly locates the caliper to suit the rotor width. they all run the same size pistons in the calipers (and pad size VB-VS) however the later model V8's (VL or VN onwards i think) got the bigger 1" master for better pedal feel.
    just noticed that this is a thread dig. didn't notice when i first replied
  19. #19
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by immortality View Post
    So would running the 1inch master be the way to go? Im assuming it wouldnt work to good if still running drums on the back?
    and yeah its a thread dig, but its now striked my interest lol.
  20. #20
    Apr 2006
    Auckland NZ
    yeah, 1" M/C will give a slightly better pedal feel. not sure on the drumbrake thing. only ever used disks on the rears with the bigger fronts. can only try it. i think you may have to change the wheel cylinder to a smaller size in the drums. alternatively fit disk rears, shouldn't be to difficult. what diff does your VK have? if it's a later model with a BW i think you can convert yours to disks using a donor diff (complete from disk to disk) from any other BW diff like VL/VN/VP etc
  21. #21
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Heres the vx booster and master fitted to my vh...works a treat
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
  22. #22
    Apr 2006
    Auckland NZ
    Quote Originally Posted by markovr View Post
    was it a direct bolt in? my VN booster is shagged and i'm intending to do the same upgrade.
  23. #23
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Oh ok, thats alright, so using the V8 Master/booster, calipers and mounting brackets, rotors and pads and she should be all go?
    Not sure what my diff is, what the easiest way to check?
  24. #24
    Apr 2006
    Auckland NZ
    yep. the easiest way to check is to see how the driveshaft is mounted to the diff. if it's using "U" bolts straight around the universal cups it's a salisbury, if it uses a flange arrangement it's a borgwarner. only the later model VK's got em
  25. #25
    Nov 2003
    northside brisbane
    Not quite...modified vr booster bracket...., redrilled pushrod hole, 3 line adapters ,vs resevoir .....but the rest is boltup....old master was shagged(using all fluid in resevoir in 3 weeks) and was a more economic way of fixing/upgrading ...took me about 2 hours .....remove and install all bled up but that nut on left stud of bracket under column is a bitch to do up.
  1. VS brake upgrade
    By wado in forum General Discussion
    Last Post: 30-08-2009, 04:34 AM
  2. Spongy Brake Pedal after VT Brake Upgrade
    By DJ Ice in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2008, 08:48 PM
  3. brake upgrade
    By kirks_vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-11-2007, 10:06 PM
  4. Brake Upgrade
    By Stewart1000 in forum General
    Last Post: 17-11-2006, 05:24 PM
  5. Brake Upgrade
    By ChRiDDa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-05-2004, 11:05 AM
