Results 1 to 4 of 4
Thread: Neutral position switch...
    KBone's Avatar
    KBone is offline Shaunoff
    VY SS
    Oct 2005
    Question Neutral position switch...
    Hi all,
    I'm putting a 5spd box into my Vk Calais (6cyl) and I've got it all worked out except for the neutral position switch and the reverse lights. If anyone has done this before I'd love to know what you did. Any info or ideas would be great.
    Thanks in advance.
    VH SL/E 1982 commodore/WB ute x2 VP commodore
    Nov 2005
    Cairns Far Nth Qld
    i assume u are going from auto to manual if so with my neutral position switch i wired it to a switch under the dash sort of like a kill switch it works well so that when it it in the off postion the car wont start and so on the reverse lights there should be on the sided of the box a few wires or a peg that they should wire into not to sure as my mate did that for me while i did the switch hope this helps
    Shawn Johnston
    Cairns Far Nth Qld
    Mobile:0488 530 009
    MSN: sbj_security@hotmail.com
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Ok the 2 purple wires on the NST need to be joined together or a switch can be placed there for a cut out switch.
    your 2 reverse switch wires need to connect onto the side of your gearbox for oyur reverse switch.
    cheers
    Scott
    KBone's Avatar
    VY SS
    Oct 2005
    That helps heaps, exactly what I wanted to know.
    Thankyou very much guys!
  1. neutral at every corner
    By musicmandaz in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-04-2007, 08:07 PM
  2. neutral saftey switch
    By pony moore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-11-2006, 05:02 PM
  3. manual conversion: rewiring neutral switch?
    By g00gz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-04-2006, 11:38 AM
  4. position of oil pressure switch on VN
    By debono55 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-08-2005, 02:09 PM
  5. Noisy Neutral
    By midnight.outlaw in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-03-2005, 11:15 PM
