Results 1 to 6 of 6
Thread: wierd vibration
    vh wagon
    Oct 2005
    castle hill, nsw
    Default wierd vibration
    i've got a vh wagon. it gets a wierd vibration that seems to come from the back end. had the wheels balanced but that justs seemed to make the vibe kick in a few km/h higher and a bit harsher. help. drives me mental. would like a list of ideas that i could go through one by one till i fix it. thanks
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Wheel bearing, tailshaft, a bump in the tyres?
    VTSS GEN3, VKSSA REP V8, VP BT1 V8
    Feb 2006
    darlington
    fitykemp is offline VH SL/E 1981
    81 SL/E
    Aug 2004
    synoptica's Avatar
    synoptica is offline Stripping VK - PM me!
    VT povpack wagon!
    Nov 2004
    Hawthorn East, Vic
    I spend a few hundred trying to track down a vibration. Car was a bit out of tune so I had the carby looked at, was out of tune and the car did run better - but the vibration was still there. Got a new cap and rotor too, and reoiled my air filter... problem still existed (was pretty sure it wasn't any of this to start with but it needed doing regardless...)
    Next was tailshaft balance, center bearing and unis. Almost $200 later, felt slightly better all round, but the vibration was just as bad as before.
    Clutch needed doing too, so had this done. Problem solved! Car felt amazingly smooth (well, not Ecotec smooth but still a hell of a lot better). Clutch was rooted and a bit out of shape but the flywheel must've been warped to hell which would've contributed to the demise of the clutch, I'd say.
    So - if it's a manual - get it sussed out. Don't know much on autos, but I've heard the flexplate can suffer similar warpage and will cause similar issues.
    Good luck sorting it out
    vh wagon
    Oct 2005
    castle hill, nsw
    thanks guys should have mentioned,
    efi v8
    new gearbox
    new clutch and flywheel
    new tailshaft
    new LSD diff
    though the rear tyres don't have much left on them, would it be possible for me to notice a flat spot or something on them?
    what are the odds that a new tailshaft is stuffed? because that was were i was headed next. after tyres that is. how much is it to check the balance on a tailshaft?
    oh and i put all of the above in myself what are the odds i put the diff in backwards or something?
  1. wierd noise PLEASE HELP!!!!!!!!!!
    By fatbt1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-06-2011, 04:28 PM
  2. Wierd vibrations
    By ragrim in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-02-2007, 03:13 PM
  3. wierd thing..
    By VL Berlina 5speed in forum Jokes/Humour
    Last Post: 27-07-2006, 12:27 AM
  4. Wierd SS grill??
    By 2_SeeK_U in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-06-2006, 05:35 PM
  5. wierd problem
    By VRSS in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-04-2006, 03:05 PM
