Results 1 to 7 of 7
Thread: VC Questions.
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Cool VC Questions.
    1981 VC Commodore Auto 3.3L Blue Motor
    1# Can coolant be used in this vehicle?
    2# best fuel to use? Atm I use unleaded with the lead replacement stuff.
    3# Auto choke? The cars accelerator gets stuck with the timing screw getting caught on the idle cam, is there a way to fix this?
    4# Car idles at 800/1000rpm mark is this good at all? The idle can jump sometimes but im still to time her...
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    1: Yes corrosion inhibitor coolant should be used with the vehicle, If you really want to make a difference use demineralised water instead of tap water as well.
    2: 98 Octane unleaded will suffice for this car, as long as you use a fuel with sufficient octane you done need to use an LR additive. Check the archives I have posted re this in great detail before.
    3 & 4 : Sounds like the carbie isnt tuned 100% correctly I would first of all set the timing, then adjust the carb correctly. Idle speed seems just a fraction high but still ok.
    cheers
    Scott
    Goon's Avatar
    Feb 2006
    GC. QLD
    Another Question..
    How would extractors work out for this commie?, with the current engine clock at 275,***
    vh sle
    Jul 2005
    sydney
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Quote Originally Posted by Goon
    Another Question..
    Fix the above first.
    Goon's Avatar
    Feb 2006
    GC. QLD
    Thanks guys, i dont think the clock even turns anymore, well without plates atm i cant drive very far... But i still dont think it does, would this mean something?
    Oh yeah i tuned the car today and there's a strange noise from the engine. " it's like someone taping on a window "
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Check for leaking exhaust gaskets, also flange gasket under car. Could be noisy lifters in the motor causing the rockers to rattle. First check for leaking exhaust. Maybe check the manifold/header gasket.
  1. CPI lpg questions
    By Outlaw Torn in forum General
    Last Post: 18-09-2006, 09:09 AM
  2. Two Questions
    By jamo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-09-2006, 10:21 PM
  3. A Few Questions
    By 4PLAYN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-08-2006, 10:29 PM
  4. 2 questions
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-09-2005, 03:54 PM
  5. VY 914 Questions
    By mungx2 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-09-2005, 06:24 PM
