hey
we were just looking at what we should replace the thermo fan in our car with we searched the forums....and found that:
Thermo Fan = More Heat + More Power
Clutch Fan = Less Heat + Less power
we were impressed with power difference between our 2 cars...one has a thermo and one the original clutch(which is pretty much screwed)...
is there a modification we can make (legally) to replace the power loss for putting a clutch back on...as the car is a daily driver, in traffic and we have always had issues with hot cars...heat is something we would rather not have to worry about
thanks
Yeah the thermo is nice I had to run one when I had my hot 202 as I kept restroying water pumps at high RPM
I am running a smaller nylon fan on my daily driver instead of the big 7 blade clutch fan, which has been a happy comprimise between the 2.
Otherwise is you want to runt he clutch fan try fitting a 4 blade fan off a non airconditioned model.
cheers
Scott
when you say you been running the nylon....you mean a thermo....or a nylon replacement for the blades on the clutch...i'm confused....
nup just a nylon fan I scabbed sitting in the corner of a workshopI dont know what its off, bit it bolts up perfectly straight onto the water pump (note use shorter bolts).
Works a treat better pickup, the fan is much lighter, a bit smaller in diameter, runs a little warmer on hot days but most of the same just normal running temp.
see the attached pic
cheers
Scott
what cowl are you using there....looks nothing like the one on our beta car
