Sup all, the speedo in my VC seems to want revenge, it would count K's every now and again but would just cut out. i can't link when it goes or not to anything else, it seems to be random, so any advice would be helpful.
PS: i rely on the k counter to guess when to fill LPG tank.
Worn/slipping gears in the speedo are your problem. Here's a link to help you fix it:
http://hometown.aol.com.au/Commodorenut/speedo.htm
Mark.
Also might be a worn slipping driven gear on the end of the speedo cable in your gearbox.
Cheers, thanks heaps, hope it ain't Zoists' suggestion ( no offence)
I would hope it's my suggestion. I'd rather get under the car and unscrew a screw than pull the whole dash off.![]()
I hope zoist is right too.
I wouldn't go so far as to say the whole dash needs to be pulled apart if I'm right. But it will still test your patience unfortunately.
I commented on a step to take. I'd check the speedo gear first to see if the gear is maybe slipping with the cable etc...
There are a lot of screws to take the dash off and my point was to check out the speedo gear first. Good luck.
Ive had this same problem the only thing i havent replaced now is the gear that sits in the transmission im hoping this is it as i dont know what else to do ive even tried a speedo without cruise control thinking my transducer had started playing up.
