Results 1 to 10 of 10
Thread: 5 speed manual 308
    VH SLE
    Nov 2005
    Default 5 speed manual 308
    ive been thinking about putting a 5 speed maula behind the 308 to come instead of a worked T350 auto. im thinking of a 5 speed from a vn 5ltr or mabey newer. the 308 is a turbo pattern. will it go in pretty easily or is it a bit of work? what gearbox do u guys reccomend.
    "From where i was, it looked like the cars you were overtaking were sitting still"
    Check out my VH SL/E
    http://forums.justcommodores.com.au/...ad.php?t=23160
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Just a matter of using a normal VH V8 manual clutch setup, get a T5 & Bell housing, make sure you get the front part of the tailshaft or the whole thing.
    Check out my site for gearbox crossmember info, speedo cable etc.
    your tail shaft rear will unbolt & bolt the front section of the VN shaft up to your salisbury rear. The VN uses different sized unis so this is the way to do it, have a look for more info on my site.
    cheers
    Scott
    VH SLE
    Nov 2005
    cheers for the help ill check out ur site. i want to use a solid one peice tailshaft once i get a 9 inch diff. what will i need to do then?
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    To use a one peice tailshaft you need to make a lot of mods to the floor, Commodores aren't designed to have one. I *think* you need to get the floor engineered for it.
    phat_com's Avatar
    phat_com is offline VR IS A BEAST WITH NEW V6
    VR s2 Acclaim/VK IS GONE :(
    Jan 2006
    Tuggers (da hood),ACT
    lol
    I *think* you need to get the floor engineered for it. hehehe hi how can i help you? um i need to get my floor engineered please
    um sorry you what?
    lol had a good laugh at that
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    Well smart arse How about you look into facts before mouthing off, cause you do need to get the floor re-engineered for one piece tailshaft cause it will hit the floor if you don't
    50 stevo Guest
    hey bloke, its alot easier to get your standed tailshaft worked on and modified to suit the box rather than going to the expence of getting a bracket made for under the car, but for the dude who went he he he how about you get a bit more constructive, rather than bagging people, if you know how how about you tell the bloke, considering thats what this web site is for not ********s who feel tough bagging people with computer buttons.
    VH SLE
    Nov 2005
    what kind of work needs to be done to the tail shaft?
    50 stevo Guest
    Default tailshaft
    you need to ring a company called petron in brisbane to get the exact info but you need a yolk and front joint modified to fit a manual, and maybe get the actual tail shaft strenghened. The only reason i know this is because we tried to go the other way, and could find a place to mount a bracket for the one peice shaft, so petron did the mods to my old vk ss two peice shaft i dont know exactly how but they should be able to it was a long time ago, but i know their still in business, i checked for ya, good luck.
    VH SLE
    Nov 2005
    cheers for the help.
  1. vn s 5 SPEED MANUAL
    By roxymusic in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-10-2007, 02:25 AM
  2. 4 Speed Auto VS 6 Speed Manual?
    By Wicked_D in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-03-2007, 02:09 PM
  3. 6 speed manual
    By camshafto in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-08-2006, 10:52 PM
  4. 5 speed manual
    By VRSS in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-05-2006, 09:55 PM
  5. F/S VN 5 speed manual
    By str8up in forum Parts And Other Items For Sale
    Last Post: 28-09-2005, 04:40 PM
