hey guys
im wonderin can u put an air filter pod onto a vk calais 3.3ltr efi?
if so do i need to do nething with a airflow sensor?
cuz the local store says u cant cuz of the sensor
i am wantin better air flow threw the motor
thanks
If your still running the Jettronic injection you dont need a pod
Just to give you an idea a VL Walkinshaw runs exactly the same sized airfilter as whats in your car.
Basically you have to run your AFM just bolt the pod onto the AFM, although unless you box it in it will be illegal.
The best option if to use a washable K & N panel filter in your existing airbox.
cheers
Scott
thanx alot scott
i mite just do that
i just liked the idea of runing a pod on it
