Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: rims on vh
    vn ss
    Oct 2005
    Default rims on vh
    hey guys and girls
    just wondering what i would have to do to put a set of 18x8 vy ss mag wheels on the vh?
    would there be much modfying? engineers certificate needed? rubbing on guards etc
    cheers
    rohan
    Aug 2005
    If the overall diameter of the wheels is close to your original's (so use the correct profile tyre) you shouldn't have any problems in that regard. The only thing which i am unsure about would be the width of the rim, even still, i would think that they'd fit pretty well. I have seen many pictures of vb-vk's with 18's or even 19's on them, so they should fit ok.
    VH SL/E 1982 commodore/WB ute x2 VP commodore
    Nov 2005
    Cairns Far Nth Qld
    You will need to roll your guards and maybe change the speedo gear cog on the end of your speedo cable i think but i have seen VB to VK with 18" rimes and low profile tyers on they look all right
    Shawn Johnston
    Cairns Far Nth Qld
    Mobile:0488 530 009
    MSN: sbj_security@hotmail.com
    phat_com's Avatar
    phat_com is offline VR IS A BEAST WITH NEW V6
    VR s2 Acclaim/VK IS GONE :(
    Jan 2006
    Tuggers (da hood),ACT
    Quote Originally Posted by fatboy2869
    there was a vc station wagon down the road on fat johns tow truck the other day and it had 18" chromies
    and my mate has vt? SS 5 spoke rims on his vl so they should fit fine
    VN SS 5speed
    Jul 2005
    ok, my mate has a vk on 18" mags, and all he needed was the guards rolled (this was mostly because the car was also lowered)
    now, since your vh probably came with 14" steel wheels (mine did) these 18" wheels would be too large (as you are only allowed to alter the wheel diameter by 2").
    you can get an engineers certificate to say the wheels meet adr requirements blah blah but i think that will cost you around $500.
    if you don't get this done u can get defected for the larger wheels, but more imortantly your insurance company can refuse to cover u in an accident because your car is not roadworthy.not meeting ADR requirements. i've heard of a person with aftermarket cold air induction having an accident and the insurance company refused to cover him because he hadn't made them aware of the modification (needless to say he is taking it to court).
    so yeah, just keep that in the back of your head
    cat? isnt that an animal? no i dont want one in my exhaust system thankyou very much...
    my ride \/
    http://forums.justcommodores.com.au/...ighlight=seabs
    Aug 2005
    I thought that if the wheels had the correct profile tyres, which make the overall diameter legal. Each state has different rules on how much bigger the overall size can be, in the ACT it is 15mm larger, or 25mm smaller. So i would have thought that if the wheels are roadworthy in your state, the insurance company shouldn't have anything to bitch about. It's just a matter of rolling your gaurds if it needs it.
    clixanup is offline Has Left
    Jan 2004
    Quote Originally Posted by Jimboss
    That won't stop 'em though.
    RACV allows up to 1" larger than the largest size for the model. EG. on VH the largest rims you could option were 15". So the largest RACV would allow on that model is 16".
    I hope that helps.
    vn ss
    Oct 2005
    hey all
    well i prob will be buyin the rims of my work mate when i can get my car rego'd in about 6 months. i live in victoria so does anyone know the rules about this in vic?
    about the size my mate at work has these on his vn ss and he gets away with it fine. i always thought they were too big legally for the vn?
    well i can put them on and if i get a defect notice guess ill just have to take them off.
    does it cost much to get guards rolled?
    cheers
    rohan
    VN Calais
    Feb 2006
    I think in Vic (dont quote me on this) that you can legally go 2" larger than the biggest factory fitted wheels.
    VS Commodore Omega
    Apr 2005
    Remember that factory fitted can also include HSV/HDT variants, this is how my brother got away with it.. VL Walkinshaw had 16"s, so he has 18"s
    Aug 2005
    Well in that case, you could get away with 18's on a VH as the VH SS Group 3 had 16 inch Centra Wheels.
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    Quote Originally Posted by Juzza
    That doesnt work here because HSV/HDT had the tyre placards to back up the wheels... So here you can only go 2 up from what YOUR car had... not 2 up from any option on your model
    I know my mate had a hard time with coppers one nite about his Holden By Design - had to show them the tyre placard.... His HBD came with 18's so he can go 20's
    D.
    VH LS1
    Sep 2007
    NSW
    What offset do you recomend for a VH with 18" and 225/40? What are they standard?
    VC
    Oct 2008
    If you look up the wheel deal on this forum you will find a spread sheet outlining what wheels are legal, you will need 225/40x18 tyres for it to comply.
    I had 17x8" VY rims on my VC with 225 tyres and there was very little clearance between the tyre and front strut. Guards should not need to be rolled, my VC is lowered and had no problems. Sold the 17's and now have 15x8" Simmons 3 piece.
  15. #15
    VH LS1
    Sep 2007
    NSW
    yes, but the question is what offset? My Vp was 31P, what is a VH 38P?? The wheels I am buying are blank centres and can be machined 35P - 45P. What is best offset for the 225/40x18?
  16. #16
    VS Calais & vh sl
    Dec 2006
    deception bay
    thats funny cause i have 17x8" vt clubby wheels on my vh with 235/45 17 and have 10-15mm of clearance between the tyre and strut, my car is also lowered and doesn't have guards rolled. the only problem i have is being a wagon even with the slightly wider vl disc diff it scrubs the inner wheel whel when goin up driveways.
  17. #17
    VH LS1
    Sep 2007
    NSW
    my question was offset, obviously you have a different offset, what are they???
  18. #18
    commodore
    Aug 2009
    australia
    i had 18'' wheels on my vk with no problems at all no rubbing or nothing and it had king ssl all round rears cut aswell (didnt think they were low enough)
  19. #19
    VY S2 EXEC
    Oct 2007
    VS Calais & vh sl
    Dec 2006
    deception bay
    Quote Originally Posted by xmick View Post
    ill look and see but i know the vt has +45 on it now and they aren't the same back spacing as the original wheels which are on my vh now.
  21. #21
    VS Calais & vh sl
    Dec 2006
    deception bay
    ok 19X8 +45 with 245/35 kings superlows and adjustable panard and they are very tight but amazingly don't scrub even with a load in the back and tuckin rim!
    Attached Thumbnails Attached Thumbnails rims on vh-mini-imgp3230.jpg   rims on vh-mini-imgp3233.jpg   rims on vh-mini-imgp3228.jpg   rims on vh-mini-imgp3234.jpg   rims on vh-mini-imgp3229.jpg
  22. #22
    VH SS
    May 2009
    Toowoomba, Qld
    as mentioned, if you get the right profile (which you need to by law in order to maintain the same rolling diameter) then you can fit basically any diameter wheel on your car without modification or speedo gear correction.
    However when it comes to the legalities of it all, different states have different laws. Qld you are allowed any diameter wheel, providing the rolling diameter is within a set tolerance
  23. #23
    tim005's Avatar
    tim005 is offline Yet Another VS Ute Owner
    99' Series 3 VS S-Pac Ute.
    Feb 2009
    Melbourne.
    there is no 2'' inch rule in victoria.
    it was phased out years ago.
    i was under the impression there was too a while ago but i was correctly informed by the wheel deal.
    check his spreadsheet as said above.
    http://forums.justcommodores.com.au/...first-car.html My VS Ute, 99', S Pac, 5 Speed.
    Quote Originally Posted by maldotcom2 View Post
    Also, always go into a corner in second gear in case you see a hot chick or another commodore you can fang it out sideways.
  24. #24
    VS Calais & vh sl
    Dec 2006
    deception bay
    yeah all states are pretty much the same now with the no greater then 15mm bigger.
  25. #25
    VB commodore
    Sep 2010
    cairns
    Darren is right above in QLD you can change rim size as long as overall diameter stays the same as original (engineer blue plater has said) thats looking after my VB blue platin... im runnin 245/35/18 on rear and 235/35/18 front
    The wheels tuck in the guards very good but i dont know what offset the are???
  1. vz ss rims how much!!
    By oozinpsi in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-01-2010, 07:25 PM
  2. VE GTS rims on my VY lol
    By Kid_Dynamite in forum General Discussion
    Last Post: 10-02-2007, 02:28 PM
  3. Genuine Rims vs Fake rims
    By drewins in forum General
    Last Post: 12-02-2006, 09:55 PM
  4. fs: wh statesman rims + vt berlina rims
    By bennyballbag in forum Parts And Other Items For Sale
    Last Post: 20-01-2006, 03:55 PM
  5. Vl Calais Rims For Vh Sle Series Ii Rims
    By Joshy in forum Swap / Wanted to Buy / Trade
    Last Post: 05-04-2004, 02:29 PM
