Results 1 to 11 of 11
Thread: Pinging
    03 VY V6 S2
    Oct 2005
    Default Pinging
    I have a 202 EST and most of the time it pings if i accelerate normally under load. Im using 98 octane fuel and lead additive. What other thing can i do to fix the problem? Would changing the ignition system do anything?
    clixanup is offline Has Left
    Jan 2004
    Quote Originally Posted by unregistered
    I once had this problem on a red 202. I'd tune it to factory spec, but it'd still ping going up hills. Long story short, it was the advance springs in the distributor. Apparently they stretch over time. Changed them and all was well again.
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Disconnect your vacuum advance on the distributor and see what happens.
    It might even just need proper tuning.
    Jan 2004
    Quote Originally Posted by zoist
    Probably not much. Vacuum advance on Commodores is only used at idle. At higher speeds, the distibutor uses centrifugal advance. It was the springs on the cetrifugal advance 'weights' I was referring to.
    I might even just need proper tuning.
    Normally, I'd agree, but his car has EST.
    synoptica's Avatar
    synoptica is offline Stripping VK - PM me!
    VT povpack wagon!
    Nov 2004
    Hawthorn East, Vic
    No vac advance on EST guys!
    I don't know how many times this has been said, but...
    DITCH THE EST! You'll never regret it dude.
    My car has never pinged (except when I've advanced it too far) with my reco VH dizzy. And that's at 9deg too!
    Jan 2004
    Quote Originally Posted by synoptica
    That's pretty good. What mods have you done (apart from the dizzy)?
    03 VY V6 S2
    Oct 2005
    Sometimes it doesnt ping at all no matter how hard i push it, seems to do it when the engine warms up. Im thinking maybe the est module advances too far when the coolant sensor warms up, In which case i could bypass it with a resistor.
    I will look into getting the VH distributor.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Seriously ditch the EST, It was the 1st mod I did on my run about VK.
    Like 2min after I bought it it was in the car. I bought the car and exactly where the car sat when I paid the money I put the dizzy in infront of the guy I bought it off and drove it home.
    I run approx 10deg advance on a mild 202 running 98 octane fuel, solid as a rock never pings.
    cheers
    Scott
    synoptica's Avatar
    VT povpack wagon!
    Nov 2004
    Hawthorn East, Vic
    Quote Originally Posted by clixanup
    Not much at all, surprisingly! It's a fully reco'd dizzy with regraph (which probably helps a lot - it's curved for 95RON now, not 97 as per factory specs) - took the head off and cleaned the chambers, ports and valves, VERY minor porting (so minor that I don't think it could be even called porting)... bottom end is bog-stock.
    I'm probably only pushing slightly more than factory figures - mods are probably worth a good 30HP but given wear on the engine..
    kel_VK_Calais Guest
    Mine pings too : ( I hate it. But i think she just needs a good tuning....if that doesn't fix it, then i don't know what will! Mines a VK EFI, if that makes any difference?
    VK 3.3
    Feb 2006
    Mine used to ping very badly. Changed heads, decarboned, lower compression etc, still no good. Changed to elec. dizzy and haven't looked back. Just too easy. Check that the EST module is working properly. I bet it is the problem, just easier to change dizzy.
    Cheers, Big Al
  1. pinging
    By tougHnA in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-04-2006, 10:47 PM
  2. pinging
    By skb in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-02-2006, 11:33 PM
  3. pinging
    By chris_1987_VL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-11-2005, 12:29 PM
  4. VR 5L pinging!
    By calais5l in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2004, 08:49 PM
  5. Vr Engine Pinging
    By CSD in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-11-2003, 11:52 PM
