I have just bought a cruise control module to go on my 4.2L VH SL/E. Does any one know how to bolt the unit on. It come with a mount supposedly to fit a V8, but I can't figure it out. Any other help in fitting the whole thing or website info would be greatly appreciated![]()
What parts do you have apart from the module?
I just have the main module and the control switch that attaches on the side of steering wheel at the moment. If I cant get any more info then maybe I will leave this job for later
You also need some vacuum hose and the cruise control diaphragm which sits behind the carb on the firewall. That has a steel rod that connects to the throttle lever on the carb, so when you engage the cruise, it holds vacuum.
See attached images.
