Results 1 to 7 of 7
Thread: 202 Efi Vk
    VN Calais
    Feb 2006
    Default 202 Efi Vk
    Hey folks,
    Thought i would make my first big post...
    Basically i am looking at buying a VK, as the topic says, its a 202 EFI.
    Its got 188,000km's on the clock, the body is as straight as a pencil, and the paint only needs minor work, which is pretty good for the age of the car. The guy who is selling it is asking for near on $2k for it, he says its road worthy... but i just want to know what i should look out for?
    If the car does check out to be road worthy then ill probably buy it.
    Anyway, attached is a pic of it, yes, only one, but that pic pretty much sums up the condition of the outside of it. The interior looks perfect, with the backseats looking like they have been used twice. As you can see, its as stock as a rock, which doesnt matter to me... can always change that cant i?
    Cheers,
    vp_s-pack Guest
    This is only something small, but when u open the doors see if they drop, if they dont its defantly a good thing, also look at the way the boot and bonnet open, i know that sounds dumb, but heaps of people told me to check it lol, also ur basics like if it starts first turn, how smooth it idles, lol well thats all i know, hope it helps...
    SUSPECT's Avatar
    SUSPECT is offline Banned
    SUZUKI GSX-R 1000 k8
    Aug 2005
    adelaide, southern suburbs
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    check for rust in the boot seal... cus water in there causes havoc :P VK's have enuf electrical gremlins without adding water to the mix lol.
    Yeah see how it runs, check fluids etc.. check for smoke, listen for noises, cycle thru all gears in the trans... etc... all that regular kinda stuff.
    D.
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Look under the car and check to see that all the rubber bushes are in good condition and not stripped. Check the rear trailing arm, front radius rod, link bushes etc...
    Check the transmission to see if it shifts ok, no slipping when shifting down at speed, smoke, strange noise etc...
    VN Calais
    Feb 2006
    Thanks for your replies guys
    Ill try and remember to check all that next time i check it out... which could be quite a problem for me considering my poor memory
    Also how much would you honestly be willing to pay for that car, without looking at it, just from my discription?
    -kRaZeD
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Probably no more than 2K with RWC would be ok as long as the interior isn't cactus and what I said about the bushes aren't stuffed. Make sure you check the tranny though. You could easily spend another 2K buying parts to do up the car too like I did but it depends on you.
    Make sure if you buy it to get a good alarm and immobiliser fitted.
