Results 1 to 4 of 4
Thread: Replacing the Sump Gaskets
    justinp Guest
    Question Replacing the Sump Gaskets
    Hey,
    was just looking through on info for replacing the sump gasket and one dude was asking about where to put the chains to lift the engine......do i need to lift the engine to get at the sump, or can i do it with the car on ramps/stands?
    ta
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Well its best to lift the whole motor out. There is another way with some heavy longish pipe and chain that i have been told about.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    You dont have to lift the engine but its easier to do that than remove the crossmember.
    On a 202 I normally bolt a bracket onto the rear of inlet/exhaust side of the head and another onto where the aircon compressor bolts up.
    If you dont have an engine crane etc you can unbolt the engine mounts off the crossmember (I loosen the gearbox mount as well) and using a trolly jack & a flat piece of wood jack up the engine then chain it to a beam laid across the strut towers.
    If your replacing the sump gasket it might be worthwhile replacing the rear main if its been leaking as well.
    cheers
    Scott
    justinp Guest
    thanks yet again guys
    Seems this job is gong to be MUCH bigger than first anticipated...anyone got an idea of what an engine crane is worth....i'm looking at kitting myself out sometime soon...as a computer programmer...all my pays come in lump sums...so in the next few weeks i'll be getting around 3K...and would rather spend the dosh on tools etc i need than to give it all to some dude to do the work for me...
  1. replacing gaskets!
    By ralph_vt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-10-2007, 12:52 PM
  2. V8 wont start after replacing inlet manifold gaskets
    By chromic in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-09-2007, 08:20 PM
  3. Replacing Gaskets
    By harvs01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2007, 04:57 PM
  4. Replacing Head Gaskets
    By sparkymac in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2006, 09:19 AM
  5. Replacing a sump gasket
    By tkaragia in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-10-2004, 07:07 PM
