hey guys
im looking at a VK SS and i was wondering what the main things i should look for are in regards to a genuine one.
vin numbers, build numbers,engine numbers, ets
thanks
www.brockcommodores.com
engine nymbers variy, some have VT prefix some have VC prefix.
I think also these are based on the SL Commodore.
Oh and last only colours for them, Alpine White and Astreoid Silver. The interior colours are only cerulean blue with blue houndstooth cloth insets![]()
compare all paperwork.
run it through an encumberance check, most of the time the operators will confirm over the phone if it's engine, vin and rego numbers match up as being a genuine Group 3...
how does it look?
how many klms?
190000kms,
the SS was realesed through holden yeah? not HDT? i thought that there were not brock commodores....
it is very neat, and has the original stickers and interior and exterior as described by Sl/E nut.
ive got the vin as BVK034778M
and eng number as VT500509
oh, and he says stock number is 1995
If you dont have much luck on the brock commodores site try Sid at HDT in sydney.
The interiors were based on the VK but with upgraded seats & door trims. Cerulean Blue Velour with Heringbone centres. The front seats are actually Scheel replacement seats.
High rise centre consol was used on the models I have seen, as well as a 3 spoke momo steering wheel. Vacationer/Berlina/Calais front arm rests, I have also seen them with a factory electric aerial.
cheers
Scott
Sid at HDT?
All VK SS was built buy HDT, Sid he runs HDT.
I forgot to ad Sids number 97921911
I've got one.. You should first check for build no. plate located on passenger side of fire wall. There should be no chrome on the car, door handles should be white, HDT MOMO 3 arm steering wheel with Peter Brock signature horn button. RTS SS badge just above stereo, scheel seats, parcel shelf should have a wave like shape at the back closest to rear window, color Light blue. 4 spd M21 with HDT gear knob, some have optional 5spd. Engine should have a HDT manifold and HDT dizzy. Aircleaner has a sticker with HDT 5.0 litre and brock signature on it, even though the motor is a 4.9ltrOriginally Posted by bigg_vin
On Compliance plate should read Eng. L31 Trans. M21 Paint No.1J052-D Axle. GU4 and Model. should start with the letters VK8VK19...
Wheels are 15inch Aero's and the body should have SS side skirts, rear wing and a brock nose cone.
You can also check the build no. with engine and body numbers with HDT to confirm if it's genuine.
Hope this helps
Cheers Dan (HDTSS1697)
thanks very much, that will definantly help
cheers
